It is currently Tue Jul 23, 2019 4:16 pm
 Post subject: Crack in PA 12
PostPosted: Mon Jun 03, 2019 9:05 am
Noticed a crack in my PA 12 I just picked up after first trip out. Hull had no water in it so I don’t believe it’s leaking. Is this something I should attempt to fix or should I not worry about it. I’ve read its very common in this area but usually it’s from the bottom of the hull or a part that will allow water in.
 Post subject: Re: Crack in PA 12
PostPosted: Mon Jun 03, 2019 11:26 am
Edit
PostPosted: Mon Jun 03, 2019 2:37 pm
Looks thin there and maybe split rather than cracked. The strength required is above this on the shelf the drive rests on. I "don't think" it is a problem, but keep an eye on it / coat with sealant maybe.
PostPosted: Mon Jun 03, 2019 3:17 pm
Silicone? Or should I 3m adhesive a little piece of plastic on top of it ?
PostPosted: Mon Jun 03, 2019 4:10 pm
You just need a water barrier in case some finds it's way around the molded-in fitting (not likely). Rough up the plastic and use something like 3M 5200.
PostPosted: Mon Jun 03, 2019 6:59 pm
I already put some epoxy over it, it is possible some water got in it already after cleaning the kayak. Should I try to remove the epoxy and let it dry for a couple days if any did get in there ?
Or Just remove and silicone. Also do you guys sell color dye? Would like to make the patch the least noticeable as the rest of the kayak is mint.
PostPosted: Mon Jun 03, 2019 7:13 pm
GOOP. Best thing going for filling holes, cracks or splits on just about including kayak hulls.
PostPosted: Tue Jun 04, 2019 3:56 am
Agree with the Goop. I use Amazing Marine Goop. It bonds to plastic well but does have a short shelf life once opened. Once it starts to "ball up" and turn white while applying it toss it.
I wouldn't use Goop over the epoxy though. If anything you could use s strip of Flex Seal tape over the epoxy to give you some piece of mind. I say strip because of the shape where the crack or split is located.
