mmiller wrote:
The 12 hull was 125 lbs.
You can add an access hatch and try to remove or at least dry the interior. Is the drain in the transom woking? Some seemed to be plugged. Not drilled deep enough to pass through the hull bonding material.
That's a great idea, I will do that.
The drain in the transom is working, got all the water out, but the foams are lose and damp. I will install the hatch and get wet foam out through it, and replace with closed-cell spray foam (Versi-Foam).
Do you know how many cubic feet I will need?
Victor
