Can't find serial number/need to order new sail, etc. http://www.hobie.com/forums/viewtopic.php?f=123&t=62395 |
Author: | johnt7 [ Mon Mar 26, 2018 11:27 am ] |
Post subject: | Can't find serial number/need to order new sail, etc. |
Greetings, I recently purchased a used Hobie Cat that needs a bit of work. I can't find the serial number near the rudder, even with a light sanding to try to reveal them. I will need to order new sail(s) as well as other parts, but wanted to find out what the year/model was. Below is a link to pictures if anyone can help. Thanks so much! https://www.dropbox.com/sh/6sgcpv2re6zj ... uaIoa?dl=0 |
Author: | Jbernier [ Mon Mar 26, 2018 4:11 pm ] |
Post subject: | Re: Can't find serial number/need to order new sail, etc. |
I took a look at your photos - that is a very old H14 (likely the serial number is stamps on the pylon rather than the transom if I were guessing about the vintage - late 60's very early 1970's)- here's the parts guide: https://static.hobiecat.com/digital_assets/14-16_March_2017.pdf?_ga=2.71985747.1365375971.1522075956-907556097.1487723519 (this is a joint guide for H16 and H14 combined) A new main is: 10990010 SAIL H14 MAIN WHITE US$ 950.00 If you wanted color we have that too: 10991086 SAIL H14 MAIN CORONADO '08 US$ 1200.00 To order parts just call your Hobie dealer - link: https://www.hobie.com/dealers/ |
Author: | srm [ Mon Mar 26, 2018 4:17 pm ] |
The serial number doesn’t really make a whole lot of difference. Since the boats are one-design, you would purchase the same sail regardless of whether the boat was built 10 years ago or 40 years ago. Also, the very early boats had a serial number stamped on thr front pylon, not engraved in the transom. Judging by the hull colors and overall condition, I would say it’s very likely well towards the 40 year old end of the spectrum. I would suggest you go over every inch of the hulls very carefully and inspect for soft spots before putting a single penny into that boat. sm |
