Hobie T2 (revised version of Euro-only Tatoo) http://www.hobie.com/forums/viewtopic.php?f=127&t=49166 |
Page 3 of 3 |
Author: | mmiller [ Wed Oct 16, 2013 9:42 am ] |
Post subject: | Re: Hobie T2 (revised version of Euro-only Tatoo) |
The stepper bracket does fit the T2 / H16 mast section. The fit is adequate for use of the stepper III on the T2 I believe. At most an additional pad or slight bend in the forward part of the bracket would make a perfect fit I think. Since the pole is long and attachments are adjustable. Should be no problem. If we get a chance to assemble one and test... we'll let you know. At least the T2 will be simpler as it has trapeze wire for use as anti-sway. |
Author: | amfoyle [ Thu Oct 17, 2013 1:55 pm ] |
Ah, bummer on the glued-mast requirement .... will have to figure how to store a 26ft mast (tricky!) with boat on trailer (OK) in a Wave-sufficient 18 ft garage, between summer-sailing events and over the winter break! |
Author: | JJ [ Sat Oct 19, 2013 12:34 pm ] |
Thanks for the details. I have one other request that may seem at bit odd, but may be a good sales advertisement too! It is difficult to get any size perspective from online photos and videos unless there is some common reference in the picture too. Could you post a picture of the T2 sitting on the ground/lawn along side a Wave, maybe? Or some other point of reference? Please. |
Author: | amfoyle [ Tue Oct 22, 2013 11:58 am ] |
That would be a great idea ... maybe parked end-to-end on a lawn or beach would give good perspective. |
Author: | sxrracer [ Tue Oct 22, 2013 12:17 pm ] |
Getaway and H16 are both 16'7" in length. T2 is 16' ---------------------------------- H16/Getaway 16'7" -------------------------------- T2 16' Yeah, everybody loves a smartass!!!!!! The T2 is just a tad shorter. |
Author: | JJ [ Tue Oct 22, 2013 8:45 pm ] |
Thanks, can you give a graphic of the other two dimensions too... |
Page 3 of 3 | All times are UTC - 8 hours [ DST ] |
