It is currently Wed Mar 29, 2017 5:30 pm
What is (will be) T2 D-PN number?
Less than 76.0 0%  0%  [ 0 ]
76.1-78.0 17%  17%  [ 2 ]
78.1-80.0 25%  25%  [ 3 ]
80.1-82.0 33%  33%  [ 4 ]
82.1-84.0 17%  17%  [ 2 ]
84.1-86.0 0%  0%  [ 0 ]
More than 86.1 8%  8%  [ 1 ]
Total votes : 12
 Post subject: T2 Portsmouth Yardstick
PostPosted: Mon Sep 09, 2013 8:20 pm
Just for fun -- let's speculate what is going to be T2 D-PN
See
http://offshore.ussailing.org/Portsmouth_Yardstick/Current_Tables/Multihull_Classes.htm
for comparison.
H17
PostPosted: Tue Sep 10, 2013 7:15 am
Here are some relevant points of reference, in order of increasing speed, i.e. going from slower (high D-PN) to faster (lower DP-N) at bottom. These are from the Portsmouth table linked above.
Hobie Wave = 92.1
Hobie 14 = 86.4
Hobie Getaway = 83.3
Nacra 500 = 76.4
Hobie 17 = 74
Hobie 16 = 76.0
My personal hope is that the T2 will have a D-PN in high 70s, or just below 80. This would be halfway between the H16 and Getaway. Given the T2's sail area to weight ratio of 172 sq ft/388 lbs (0.443), compared to 218 sq ft/320 lbs (0.618) for H16 and 180 sq ft/390 lbs (0.462) for Getaway, this may be a close call.
-Roland
Sailing vintage Hobie Cats in West Africa.
PostPosted: Wed Sep 11, 2013 9:22 pm
Africat wrote:
My personal hope is that the T2 will have a D-PN in high 70s, or just below 80. This would be halfway between the H16 and Getaway. Given the T2's sail area to weight ratio of 172 sq ft/529 lbs (0.325), compared to 218 sq ft/320 lbs (0.618) for H16 and 180 sq ft/390 lbs (0.462) for Getaway, this may be a close call.
Agree. As it looks, most of the difference is in sail area between T2 and Getaway in jib size. Tatoo has main/jib sail area 140/32. I do not have main/jib area for Getaway, but just looking at the boat picture, jib is relatively large comparing to the main. This seems to be a trend in new cat design: small jib, bigger main, taller mast, and overall better performance as per total sail area. For example, Nacra 500 has main/jib area 152/38 (total 190) as compared with H16 153/55 (total 218). Both H16 and N500 have about the same D-PN.
H17
PostPosted: Sun Jan 05, 2014 9:07 am
the weight is 388lbs not 529lbs which is capacity
PostPosted: Mon Feb 17, 2014 9:15 pm
Thank you for catching that, hobie17li! That weight above 500 lbs should have made me suspicious. I went ahead and corrected the numbers in my post above.
-Roland
