It is currently Tue Apr 23, 2024 11:01 pm
 Post subject: Hobie 18’ restoration?
PostPosted: Tue Jun 15, 2021 12:34 pm
Need a little guidance on how to fix a 18’ hobbies I bought.
1. It needs to be sanded and repainted. What grit of sand paper should I use and what paint or epoxy do I need? I was told to watch out for blue toxic dust from sanding it. Also can I roll the paint on instead of sending it to a shop to do it?
2. I’ve looked into buying all new ropes for it since most of them are falling apart. I’ve looked at west coast sailing for a package deal on everything. Any suggestions of another company that is good to use?
3. Does anyone have a sheet or layout of how to rig this 18’ hobie? Not sure what year or model it is but I’m ready to sand/paint/ and get it in the water to sail again.
Thanks for any info and help.
PostPosted: Wed Jun 23, 2021 1:14 pm
You can go here for H18 reference material: https://www.hobie.com/support/hobie-18/
MLurrays.com is a great place for hobie parts...
where are you located?
Paul Evenden
NRO, RMMCC, CJ
PostPosted: Wed Jun 23, 2021 2:45 pm
Discussions on painting: https://www.hobie.com/forums/viewtopic.php?f=13&t=51094
PostPosted: Fri Jun 25, 2021 5:57 am
for a line kit there is a pretty affordable one from Slo sails
https://www.slosailandcanvas.com/line-kit-to-fit-hobie-18-catamaran/
PostPosted: Tue Jun 29, 2021 8:44 am
I bought all new lines and bunjees for my Hobie 16 from Cajun Rope. Good prices.
https://www.cajunrope.com/store/p9/Cajun_XLE_-_Free_Shipping%E2%80%8B.html
You can see the lines in the video from our first sail:
https://youtu.be/GOX88EIhWDw
We replaced the halyards, main and jib sheet, trampoline lacing, batten ties, trapeze adjusters, and outhaul. Cajun didn't have the line for the batten ties that I found, so I got some from Murrays and some from Sailrite.
Bryan
Poplar Grove, IL
1977 Hobie 16 (died a spectacular death https://youtu.be/Y7O22bp2MVA)
1978 Hobie 16
PostPosted: Tue Jun 29, 2021 2:59 pm
1) Sanding and painting the boat is a lot of work, and if it's still the original gel coat you can actually restore the finish for less work than it'd take you to sand and repaint it. I just refinished a set of blue '78 hulls and they shine like new! Gelcoat is a better/more protective top layer than paint, and once you paint the hulls, you can never get the gelcoat finish back (it doesn't stick to paint).
All it takes is some 3M Rubbing Compound and a variable speed buffer with a wool buffing pad... that'll take all the oxidation off and polish them right up! (it might take 2 or 3 passes for the decks, mine did). $30 for the rubbing compound, $40 for a buffer at harbor freight and $20 for the buffing pad. Way quicker & cheaper than sanding & repainting.
If you have some really stubborn oxidation, you can use sandpaper... I'd start with 1500 grit, and if that doesn't work try 1000 grit or worst case 500 grit.
If you want the hulls to really shine, 3M Finesse-it II and a foam polishing pad can give you a pretty impressive finish! A coat of Starbrite Marine Polish with PTEF (sealant) and Wax will keep it shiny for years to come!
I've also re-done the gelcoat on my old boat, and I was able to just roll that on.
2) With regards to replacing the running rigging (ropes), there are replacement rigging "sets" you can find on ebay through slo sail & canvas, salt city sailing, salty dog marine, but you can just as easily replace the lines at your local Hobie dealer/sailor supplies store: https://media.hobie.com/2010_archive/su ... eGuide.pdf
I'd highly recommend replacing the standing rigging (wires) at the same time, since they're likely just as old as the running rigging and under much more stress/more likely to fail. You can get a complete set from the above mentioned ebay sellers for a good discount over what they cost individually.
3) Here's the assembly manual for the boat, it should help: https://media.hobie.com/digital_assets/ ... Manual.pdf
Mike
'78 H18 (unnamed) sail #14921
'08 H16 sail #114312
'97 H21SC sail #238
