It is currently Tue Apr 23, 2024 3:48 pm
 Post subject: Wing Slug Removal Help
PostPosted: Wed Mar 26, 2014 5:59 pm
The starboard rear mount point for wings has a long 1/2" diameter stainless steel slug that fits into the rear crossbar. It's longer than the other three mount point slugs and I can't figure out how to remove it. Any great ideas?
Thanks!
Mark
2007 Hobie Tiger
PostPosted: Wed Mar 26, 2014 6:07 pm
I'm pretty sure you have to drill out the rivets on the corner casting and remove the casting to get that slug out.
My 18 is a standard (non-magnum) and it has this slug - presumably installed by the factory in the event that the boat would ever have magnum wings installed. I think this slug is longer so that it can bridge the opening for the tramp.
PostPosted: Wed Mar 26, 2014 6:12 pm
Thanks, I hope that's not the case! My other option (so far) is to lengthen the opening area just enough to get it out.
2007 Hobie Tiger
PostPosted: Thu Mar 27, 2014 2:36 am
Removing the corner casting is no biggie. Just drill out three rivets and pop it off. I'd certainly do that before grinding the opening larger.
PostPosted: Thu Mar 27, 2014 10:55 pm
its junk.... you should sell me the wings.... :shock:
PostPosted: Fri Mar 28, 2014 6:12 am
Why do you want it out?
PostPosted: Fri Mar 28, 2014 6:45 am
I'm selling the wings and need to give the hardware to the buyer.
2007 Hobie Tiger
PostPosted: Fri Mar 28, 2014 7:34 am
I would have the buyer check to see if the slug is already installed in his boat. Like I said, I think this is something that may have ended up being installed in all the crossbars by the factory, so it's possible that it's already there. I know it's on my '85 boat and that has never had magnum wings. Keep in mind that it may be hidden behind the hull saddle. It would certainly be worth a look.
PostPosted: Fri Mar 28, 2014 1:58 pm
That's an excellent idea! I'll ask the buyer to see if it's already on his boat.
Thanks!
2007 Hobie Tiger
PostPosted: Sat Mar 29, 2014 3:26 pm
Ok, the buyer's boat didn't have the long slug so I just bit the bullet and removed the casting. It wasn't too big of a deal after all.
Thanks Everyone for the help!
Mark
2007 Hobie Tiger
