It is currently Mon Mar 27, 2017 1:18 am
 Post subject: Beach wheel suggestions?
PostPosted: Mon Nov 07, 2005 12:02 am
Now I'm looking to buy some beach wheels, but am a little baffled by the opitons in the catalog. Any sugggestions?
PostPosted: Mon Nov 07, 2005 7:08 am
I bought some Cat Trax out of the catalog. Expensive, but well worth the money. They do really well on the soft sand. They also fit on my trailer perfectly.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: Cat Trax
PostPosted: Mon Nov 07, 2005 2:52 pm
I also have Cat Trax and in the soft sand of MI they work great. Get the cradles also. I bolted two parallel pieces of steel galvanized conduit down to my trailer and can slide them under the boat for travel.
Expensive but worth the money.
PostPosted: Wed Nov 30, 2005 9:49 pm
Try these, will cost you less than $100 if you don't need cradles and under $200 if you do. :) :) :)
http://www.geocities.com/mec_coleman/tip13.htm
I made some of these. Work GREAT on soft and hard sand. 8) Not to good on uneven ground. :x VERY light, just put on hulls and tie to trailer.
Doug
281-326-2702
PostPosted: Thu Dec 01, 2005 4:15 pm
Check out this beach wheel design!
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 4594360818
 Post subject: Same Barrels
PostPosted: Sun Dec 04, 2005 12:01 am
What more needs to be said. Those are the same
barrels that I used. :)
Doug
PostPosted: Thu Dec 08, 2005 2:47 am
How do you attach the beach wheels so they do not slide when pushing the boat?
Mine slide back, however I suspect that this may be due to the small wheels that I am using.
I will be trying the suggestions in the links. Thanks all.
Cheers
Alan
PostPosted: Thu Dec 08, 2005 9:18 am
You connect a line to the ends of the beach wheel axel. Then you tie the bitter end of that line to the shrouds when the wheels are under the boat.
Nick
Current Boat
In the market
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
Users browsing this forum: dave202 and 1 guest
cron
