It is currently Sun Dec 17, 2017 4:57 am
 Post subject: Inspection Ports
PostPosted: Sun Feb 19, 2006 5:56 pm
Looking to add a inspection port to each hull behind the rear crossbar.
The question is WHAT SIZE?
This port would be to install anchor plates to the rear crossbeam. If anyone has added these ports please let me know what you did & what size will fit.
DVL 1989 H-18 Worlds Boat, Magnum Wings & Spinnaker
dale.vanlopik"at"att"dot"net
PostPosted: Mon Feb 20, 2006 7:31 am
5" is the most common diameter, four and six are also available. When installing make sure the cut edge gets a good coat of epoxy or polyester resin to prevent water from seeping into the foam and glass. A 1/2 to 3/4" thick piece of foam works well to seal the ring affixed to the hull, the remaining center piece of foam may be glued to the bottom of the "cap" so it will float. Search on thebeachcats for complete installation details.
Fleet 297
PostPosted: Tue Feb 21, 2006 9:24 pm
I thinnk John is talking about using closed cell foam. It floats much better than the open cell variety.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Tue Feb 21, 2006 10:36 pm
I am considering doing the same. Please share your experiences with me, either on this Forum, or at lunnjohn@magma.ca I am particularly interested in understanding how to mount the anchor plates and placement of the fibreglass reinforcing strips.
My new (used) SX 18 wings arrive March 5, all the way from California, and like you, want to make sure that the hull-deck joint is solid and strong.
Still snowing up here, and I can't wait for May.
Good winds
1989 Hobie SX18 Sail # 1947 "In Theory..."
