It is currently Thu Jan 18, 2018 11:04 pm
PostPosted: Sat May 13, 2006 8:19 am
Heya folks, looks like you all have a wonderful community here. Seems to be a lot of good info lying around, it'll just take a little while to absorb it all ;)
Im new to this area of water sport, and water relaxation. And ready to jump in with both feet. I just recently bought a H18, I have reppaced all the ropes (rigging?) and rep'd all the tramp ropes with shock cord.. I understood I would have to do all this, and think i got a good deal on the boat. We will see next weekend when I launch it :) .. ( and i've got SOO much to learn.. I realize I have just scratched the surface)
I had a quick question though about my Serial Number. I read Matt's post detailing what each section of the SN means.. To no avail, I turn to you all.
S/N (hull) #: CCMH8200M84B
Maybe im just confused, but this would make it.
Coast Catamaran Manufacturer
Model H
SN seq 8200
13th month of the year ?
1984 model
and the random letter B on the end ?
Many thanks, and I look foward to learning much with you guys.
/wave
Gann.
 Post subject: Serial numbers
PostPosted: Sat May 13, 2006 8:48 am
Serial numbers.
Yep... 1984.
The M? and the B? I know Hobie was building a ton of boats back then. Probably rolled over to the next letter (month) for the M. The B? Could be the same issue. I will review on Monday.
PostPosted: Sat May 13, 2006 12:14 pm
New here too. Just sold my h16, but had so much fun with it I bought an 18. The serial number looks like sxla0858087 there might be a 7 and a 4 following. It is very hard to read. The first sticker from LA parks and rec looks to be dated 1976. Has not been registered since '95 so it is off the DMV computer. Boat appear to be in great shape. Not cracks. Tramp is a mesh so it is probably a replacement. Any tips or cautions would be appreciated. How many number should the hull number have? Is the a website that charts the numbers. Thought I found one when I looked up for the h16. Thanks and welcome all help.
Hobie 18sx in Oceanside -
Frank
 Post subject: Serial Numbers
PostPosted: Sun May 14, 2006 1:58 pm
xcaguyx wrote:
sxla0858087
This is not a Hobie Cat serial number. The numbers are on the transoms. Here is a link to photos and description of it.
http://www.hobiecat.com/support/warrant ... erial.html
PostPosted: Mon May 15, 2006 9:05 am
Thanks Matt, The numbers are on the transom and they look like they were stamped into the gel coat when it was still soft. I have my cam with me and will take a picture. I will also look for engravings on the transom.
We plan to take it out this weekend, are there any cautionary notes? compared to the h16 the mast stepping mechanism on the h18 looks like it is is a lot easier to use.
I can't find the deck covers. I bought some replacements 6" screw-on. Are the old covers still available for purchase before I cut in the new ones?
Thanks again for your help.
Frank
 Post subject: SX18
PostPosted: Mon May 15, 2006 1:42 pm
Odd one. The molded in numbers would not be Hobie.
Picture of the boat?
You in Oceanside? Bring it by?
Pop-in ports? 61380001 still available.
PostPosted: Tue May 16, 2006 12:05 am
Where are you located in Oceanside? We go to the Hobie shop in Dana pt all the time.
Frank
 Post subject: Oceanside
PostPosted: Tue May 16, 2006 8:56 am
The factory is on Oceanside Blvd. About 5 miles in from the coast.
PostPosted: Tue May 16, 2006 6:44 pm
What are you're hours and address? I will be down in two weeks.
Frank
PostPosted: Thu May 18, 2006 7:07 am
Matt, I sent you and email via info@hobiecat.com. I referenced it to Matt Miller. I attached picts of the serial no. and of the deck ports.
Thanks again for all of your help.
Frank
 Post subject: Photos of serial number.
PostPosted: Thu May 18, 2006 7:10 am
Matt, I sent you an email via info@hobiecat.com. I attached picts of the serial number and the ports.
Thanks again for all of your help,
Frank
PostPosted: Thu May 18, 2006 12:04 pm
Here is a link to the pictures of the Serial Numbers, Hatch, and Trailer ID's. Maybe this will help someone else later. I am assuming it is a '74. The hull and deck are in perfect shape. It does need a polishing and eventually a painting. I don't think it was used much as there is no wear what so ever on the bottom. Boat appear to be complete. I will rig up to make sure all is there and that I don't fall through the tramp.
http://hctb.com/my_sailing_page.htm
Frank
Users browsing this forum: Yahoo [Bot] and 1 guest
