It is currently Fri Mar 24, 2017 12:18 pm
PostPosted: Fri Jan 27, 2012 2:38 pm
My 18 has black spars and fittings Inc rudder units
Magnum wings as they extend beyond crossbars
Sail number 14281
So could it be a 18SE with magnum wings added ?
The faqs imply I have too many numbers on the sail to be an SX?
PostPosted: Fri Jan 27, 2012 2:41 pm
Sorry SX wings because they extend beyond the cross beams
Is the main bigger for the SX?
PostPosted: Fri Jan 27, 2012 7:06 pm
Measure the length of your mast. The standard mast is 28'1", the SX mast is 29'6".
PostPosted: Fri Jan 27, 2012 11:05 pm
Yep. Either SX or Magnum wings may be added to any H18. Just the sail number says it's an 18, but to be sure, if the sail is dacron it's an 18SE, if it's mylar it's an 18SX, plus the SX has a longer mast.
PostPosted: Sat Jan 28, 2012 12:05 pm
Yep, SX wings are longer. Also, the main AND jib are larger.
PostPosted: Sat Jan 28, 2012 12:40 pm
According to Matt's 18 specs in the FAQ post, the SX version actually has less sail area than the standard H18 (240 sq' for the standard vs. 220 sq' for the SX). The SX has a taller, higher aspect sail plan but assuming Matt's figures are correct, it isn't larger.
Users browsing this forum: Google [Bot], Yahoo [Bot] and 3 guests
