It is currently Sun Mar 26, 2017 12:17 am
PostPosted: Wed Jul 19, 2006 7:33 pm
My H-18 Halyard Line and Luff Tensioner are gone on the used SX I bought. How long are they supposed to be? What is the luff tensioner made out of? Thanks!
PostPosted: Thu Jul 20, 2006 5:01 pm
This is shown in the catalog.
Halyard - RH112WHT (1/12" leech line) - 20 feet
Luff tensioner - RH018WHT (1/8") - 5 1/2'
PostPosted: Thu Jul 20, 2006 6:07 pm
I had the same situation. I bought 30 ft. of 1/8" line and a pair of sister clips. Then I used about 5 feet for one and 25 ft for the other. It works great but I can say that I could have got away with two or three feet less. The hard part is getting the little block at the end of the jib halyard to go into the pocket when you are bending on the jib. It takes a bit of jiggling.
 Post subject: What are sister clips?
PostPosted: Fri Jul 21, 2006 10:03 am
You mentioned sister clips on the post for the H-18 jib halyard. I'm not familiar with the term. Please tell me what that means. Thanks.
PostPosted: Fri Jul 21, 2006 10:18 am
sister clips are small metal line ends that hook together for temporary use. If no pics on hobie catalog try layline.com I know they have pics. I don't use them but own a pair I tried out and didn't like. I'm afraid they might detach while getting the pully into the pocket. Plus, I don't mind untieing the bowline knot. Thats all they do.
PostPosted: Fri Jul 21, 2006 11:10 am
I removed the old luf tensioner wire and have only used a halyard for some time...Now I have a new luf tensioner but have no idea how it and the halyard are ment to work...
Could someone explain with details what i should do?
I have a H18 a jib a luf tensioner and a halyard
what next :)
Should I put a small block on the end of the luff tensioner? The old one had one installed...
Thanks!
 Post subject: Halyard wire?
PostPosted: Fri Jul 21, 2006 12:26 pm
You are now talking about the actual halyard wire? The wire routs through the sheeve at the top of the forestay assembly. The shackle attaches to the jib head. The halyard line ties to the thimble end. No block needed. We quit using them (blocks) because they get hung up on the luff sleeve / when hoisting and zippering to the forestay. Hoist the jib, then tie the shorter line to the tack shackle. Pass that up to the halyard wire thimble and back down to the shackle. Tension the luff and tie off. Remove the longer halyard line and stow. Zip the luff closed and sail.
 Post subject: Halyard Wire Thimble
PostPosted: Sun Jul 23, 2006 4:52 am
Matt,
Please tell me what a halyard wire thimble is. Thank you and everyone for these wonderful threads!!!
 Post subject: Re: Halyard Wire Thimble
PostPosted: Mon Jul 24, 2006 7:20 am
Fleet 297
 Post subject: Thimble
PostPosted: Mon Jul 24, 2006 7:30 am
Thanks, I called that part a Nicra fitting. Is Nicra fitting another term for a thimble?
