It is currently Tue Mar 28, 2017 5:43 am
PostPosted: Thu Jun 14, 2012 2:37 pm
I am looking at a Hobie 18 currently in Wawa, Ontario. The hull number is CCM H 5108 M 81 H, and the sail number is 8792.
ID is CCM, Model H, Serial is 5108, Built in Model Year M, built in March 1981.
There are Michigan stickers on the boom - the most recent is 1987 #006983.
The hulls are in reasonable shape, there is some old damage to the port bow from striking rocks in Lake Superior. When looking through the inspection ports you can see that they have been rubbed but seem to be solid. She has been stored outside without being sailed for the past year (actually I believe she has been stored outside for most of her life in Wawa (since probably 88).
The cat box has mould, and the sails inside are discoloured and certainly mildewy. I have no idea how old they are, but the battens are solid. The bungie lines that hold the trapeze wires need to be replaced, as does most of the other ropes. There is a brand new righting line, and 3 year old trampolines. The boat comes with the Magnum Wings and a brand new spinnaker with a slightly bent pole. The trapeze harnesses are mildewy (three of them), and look beat up. The jib sheet is new, but the mail halyard is not really nice looking, although it seems to be solid.
The trailer needs bearings, rollers and has no padding to protect the hulls. The wiring is also shorting out. He also has the Cat Trax, with disintegrated cups at the ends of the axles.
He is asking $2,000 for the cat, and all the associated gear and trailer.
My question is, "Is this a fair price".
This is a 31 year old boat. I think that all the sheets/halyards will have to be looked at closely and/or replaced. The hulls will be fine for this season, but should really be gel coated to prevent any further damage to the hulls. If I pass my hand under the hull while looking in the inspection port (on either side), I can see the shape of my hand pass by. So I think it is wearing a little thin. The sails will have to be cleaned. Soaked, and the mildew cleaned off. Hopefully, I can get another season out of them, but they will have to be replaced. The spinnaker is nice, but I'm not ready to run a spinnaker yet - I'd like to try more sailing first. The harnesses will have to be replaced, and they are $95 or so each, so with three in the family - $300 right away.
PostPosted: Thu Jun 14, 2012 7:38 pm
Sails are very expensive. If those aren't good, you are going to spend twice the asking price before you will be sailing. Pictures are very helpful.
Garrett
94' H16 - 114050
https://www.facebook.com/groups/423463424425838/
PostPosted: Fri Jun 15, 2012 4:24 am
Get him to knock $500 off for replacement sails from Ebay, they are not too expensive there.
Fiberglass is somewhat translucent anyways. If the gel-coat is rubbed off, you would see your fingers on the other side even if the damage went no deeper than the gel coat.
2010 AHPC C2 #218
PostPosted: Fri Jun 15, 2012 6:39 am
I'm on my 2nd H18....and I've sailed H18's every year here in Ottawa for the last 22 years...plus H16's and Wave's etc.
Let's see who else chips in.....search the Forum for 'what to look for'...
Bill in upstate New York....are you there?
Here is what I would look for:
KEYS:
1 Hull condition. Those old H18's were heavy, and built like tanks, really solid. However, age has a way of creeping up on all of us. For a boat of that age, no one should expect perfection. Look for 'softness' in the decks which is a sign of delamination. Take off your shoes, go barefoot, and walk on the hulls, especially just in front of the rear cross bar. Feel any 'give'? Any material flexing? Delam can be fixed, quite easy, search the Forum. Know that it's there....
Most everything else can be reglassed. Try a leak test with soapy water.
2. Cross bar condition, especially the centre of the front cross bar...any hairline cracks? There are no more cross bars from Hobie, out of stock, out of production. There are 'fixes', but they are not pretty.
3. Good mast, eyeball it, is it straight, no dents/bumps/kinks?
4 Other stuff....just costs time and money...Lines, drain plugs, rudders, sails etc
New sails will run around $1,400 for plain vanilla...I paid $2K for Custom Pentex sails for my SX18 from Chip at Whirlwind. Who knows what's on eBay....
Ropes, lines, bits and pieces...you can spend $1, you can spend $10,000, all depends on your budget. And how 'fussy' you are. Get to know the good guys at Fogh Marine, Toronto. Or Rob Jarry at Boat Works in Syracuse.
Trailer could be worth $200, it could be worth $600
Cat box could be worth $100, could be worth $400
The wings alone are worth $500 to $700, if they are undamaged and have good tramps. And the spin set up costs $1,800 new....and I could go on.
The key is the hulls and the cross bars.
Without those, you're looking at this being a parts boat.
PostPosted: Fri Jun 15, 2012 8:23 am
Unless some has dramatically changed in the past 6 months, your #2 isn't quite right. the crossbars are out of production, but when I spoke with Matt Miller last fall, there were still decent numbers (>2 dozen of each) available. However, at $500/each, if you do need to replace the crossbars, they add up fast.
Otherwise, John's post is right on the money with what to look for. With the wings, a lot of extra stress is placed on the crossbars, so check them closely. The usual spot for wing-induced cracking is just inside the inboard edge of the hulls, towards the bottom. If it doesn't have it, you may want to add the wing reinforcement kit ($275 or so) which adds riveted SS plates to where the wings attach to the crossbar to prevent these cracks.
Pictures would be very helpful...
1990 Hobie 18SX #2077
PostPosted: Fri Jun 15, 2012 9:08 am
Thank you for your responses. Last night he called, and I offered $1600. He said he would think about it and let me know Friday, today. I did voice my concerns about the hull, the sails.
PostPosted: Fri Jun 15, 2012 10:55 am
That boat has had it's rudder set-up upgraded....to the new style.
From the little that I see, a real good cleaning would go a long way.
In parts alone, your offer is good.
For the first season, make sure there are other boats around when you go out...
just to be safe.
Good luck.
PostPosted: Fri Jun 15, 2012 4:49 pm
2 cents more.
Put the sails in an oxi clean bath! let them soak over night.
Next add the side shroud reinforcement plates. If your boat doesn't already have them its hard to see in your picture.
3rd buy new side shroud pins if you don't know how old they are.
Hope to see you on the water soon.
Corkguy 1984 H18,
Corkguy H18, H20
PostPosted: Fri Jun 15, 2012 9:17 pm
$500 - $1000 tops.
It is a project boat and a money pit. Run, and don't' look back...
H17
PostPosted: Sat Jun 16, 2012 12:32 am
Scorch2001 wrote:
The boat comes with the Magnum Wings. . .
Correction, those are SX wings. And the rudders are on backwards, switch sides.
The boat needs a bunch of work, but if you're willing to do it then it could turn out very nicely. Polish, lube, scrub it. Most of the replacement parts can still be had, such as sails, shrouds, anchor pins, sheets, halyards, main and jib blocks, port covers. As already mentioned, if the hulls, cross bars, mast, and rudder assembly, and dagger boards are in good condition then it's just a matter of how much money and time you want to spend fixing her up. Just ballparking, I'd say the cost of the parts I'd want to replace would be near the purchase price, but that's me, and I'm a bit picky in keeping my boats in safe and good working condition (I finally fixed my rudders, Cork Guy!!)
There's also the question of your local market availability for these boats and how badly you want it. I think your offer of $1600 is fair considering all the work and parts that it needs. And if it comes with the beach wheels then check the condition of the tires.
PostPosted: Sat Jun 16, 2012 6:57 am
Once again gentlemen, thanks for your help.
He called this morning and refused my offer of $1600. The weather has also not cooperated, so I haven't been able to go out with him and my family to see if everyone would enjoy sailing.
This afternoon we will take the mast down and de-rig the boat. Back into outdoor storage she will go. He is leaving back to his home in Vancouver, and I believe he is planning to post the boat on kijiji.
Kinda sad, I know I would have enjoyed the sailing. Unfortunately with my husband still a paramedic student - the budget to meet his price is not there, and there is still the cost of new/newer sails and other stuff to have fixed.
PostPosted: Sun Jun 17, 2012 5:16 pm
Gentlemen, it's been a good evening. I am now the proud owner of a 1981 Hobie 18. Thank you everyone for your help. I will be sure to be posting more questions, and pictures of my adventures with her! :D
PostPosted: Sun Jun 17, 2012 5:34 pm
Congrats on the new boat. I think with some cleaning and minor stuff you will be good to go. I love my 18 with wings.
PostPosted: Mon Jun 18, 2012 9:08 pm
Congrats. :D
Check this thread on how to clean your sails. Sound like Oxyclean is the way to go.
http://www.thebeachcats.com/forums/viewtopic/topic/13477
H17
PostPosted: Wed Jun 20, 2012 2:24 pm
You get the same H18? How much?
