It is currently Tue Jan 23, 2018 2:40 pm
PostPosted: Wed May 29, 2013 12:20 pm
Thought I'd introduce myself and boat,since I know forums are an invaluable resource when owning just about anything worth a damn. After previously owning an H18 a few years ago that was de-masted and blown away in a bad storm (long story, floating dock, sold for parts), we've been on the hunt for a new one. My buddy and I just got a great deal on a light blue '84 H18 with Magnum wings two weeks ago, and are pretty pumped! It's a two-owner, freshwater boat that is completely original from what I can tell. I drove two + hours to PA where a guy had been sailing it on a lake and drove away with it for $1200, trailer lights worked and everything :D ! The sails were repaired recently here in Annapolis, and the hulls have no soft spots or cracks from what I can tell. Rudders are good, but daggers have a few chips. We're probably going to replace a few shrouds, the jib sheets and maybe the porthole covers before rigging it up for a sail this weekend. I read many of the other posts in here about what to know before you go, but if anyone has any words of advice or just wants to drop a line - please do. Look forward to gaining a lot of useful info on this site!
Justin
H18 Magnum
Flying Scott
Pirating the South River for 10+ yrs
PostPosted: Wed May 29, 2013 2:31 pm
Picture might help. Anyone know what sort of pin I am supposed to secure the wings in the down position with?
Sent from my Nexus 4 using Tapatalk 2
Justin
H18 Magnum
Flying Scott
PostPosted: Wed May 29, 2013 5:45 pm
Two suggestions before a first time sail on a Hobie 18 - make sure you understand how the main halyard hook system works before attempting to raise the sail and make sure the rudder system is working properly, especially if you have the old style castings. Otherwise, enjoy!
Also gotta give a shameless plug- you should consider attending some of the division 11 regattas. There are several in the maryland/chesapeake area as well as delaware and new jersey. Its a good group and you'll learn a lot.
PostPosted: Thu May 30, 2013 3:57 am
Thanks for the advice. Yeah, that halyard hook system was a PITA on our last cat. It appears the rudder system is working well, just gotta straighten out one of the long pins in a vice bc it's a little bent. I'll check out division 11; as of now I've only raced monohull one-design, but I'm up for anything.
Justin
H18 Magnum
Flying Scott
PostPosted: Thu May 30, 2013 8:18 am
If you've got a bent rudder pin, most likely it is an aluminum pin. I would recommend you get a set of stainless steel pins. Plain and simple, they don't bend, they don't break. You will buy them once and they will most likely last the life of the boat. Aluminum pins will bend or break leaving you with a mess on the water.
Regarding Div 11, there are about four or five active racers (i.e., attend 90% of the regattas) and may get up to eight or ten 18 sailors as a real good turnout. The next four regattas (through mid September) are in New Jersey, so maybe not worth making the trip for you at this point. I would definitely recommend you consider the Rock Hall regatta at the end of September (Rock Hall Yacht Club). Great venue, usually a good turnout, and should be pretty close to your area. Any questions, feel free to send me a PM.
PostPosted: Fri May 31, 2013 2:16 pm
Had the day off to finally raise the mast for the first time and check everything out. Some things were ghetto rigged so I had to buy some new shackles shock cords and pins, but other than that I think she's ready to go. I am ordering some anchor plates for under the wings, getting new lines, shrouds, halyards, screw in caps and a couple harnesses then I hope to be good for the summer. Motor boating tomorrow, but hope to be flying hulls on Sunday, forecast is 10-15. Very excited. Image
Justin
H18 Magnum
Flying Scott
PostPosted: Fri May 31, 2013 3:09 pm
The PO of my '89 18 with magnum wings changed out the pins holding down the wings for the ball lock style. I wouldn't recommend this as the alignment between the wing struts and the strut tab usually isn't that good. I always have at least one that has popped up when I bring it back in. So, I happen to have recently looked up the correct parts for these. The pin you want is 1/4" x 1.328 (8020431) You can use the standard key ring type lock (20860000) or if you want to trade a little risk that the pokey end might snag a line for some convenience get the safety pin style (20503.)
-Rowdy
PostPosted: Mon Jun 03, 2013 4:56 am
Hey Justin,
Welcome to the H-18 family! I live just a few miles away in Bowie. I am also an active racer in Division 11. Let me know if you have any questions.
Jim
PostPosted: Mon Jun 03, 2013 6:01 pm
-Rowdy
Thanks, I picked up some pins that worked fine (though I already lost one somewhere!).
Justin
H18 Magnum
Flying Scott
PostPosted: Mon Jun 03, 2013 6:05 pm
jim-doty wrote:
Hey Justin,
Jim
Thanks. Lmk if you're sailing in the area, I'd love to sail with another 18. Here's us on our first tack on the boat. Was blowing stink all weekend, but unfortunately by the time we got out there the wind was dying and the storms were rolling in. Story of my life. Still glad to get it in the water. Image
Justin
H18 Magnum
Flying Scott
PostPosted: Wed Jun 05, 2013 5:47 am
I have been using 1/4X20 stainless bolts on my wings since new in 1989. Bolts make the wings tighter and take out the slop. Jim.
ADDICTION
1989 HOBIE 18 SE/sx wings
HOBIE ALTER SIGNATURE MODEL
PostPosted: Fri Jun 07, 2013 5:14 pm
Hi
I'm also a Div 11 member ... and have a H18Mag that I keep at Rock Hall on the Chester River.
Bolt down the wings ... much better
Get SS Rudder Pins ... and use the nylock bushings!!!! Place a SS Washer on top of top rudder gudgeon/under rudder casting ... prevents SS rudder gudgeon from wearing into cast Aluminum rudder casting.
Many other tricks you can learn from Jim ... Steve ... Keith and the other Div11 h-18 sailors ... some will be at Rock Hall Yacht Club for a weekend of racing on June 14-16 ... starts w/ 'Down the River' Race on Friday from Chestertown CC&YC to Rock Hall YC ... then buoys racing at RHYC all weekend ... camping on-site/bar/clubhouse ... nice area to sail/race on ...
Hope to see ya ...
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Thu Jun 13, 2013 5:28 am
Harry Murphey wrote:
Hi
Hope to see ya ...
Sounds awesome. I have family stuff to do this weekend, but hope to make it out to a div11 event soon. If you're sailing tomorrow it looks like it will be howling! Have fun.
Justin
H18 Magnum
Flying Scott
