It is currently Thu Jun 29, 2017 2:54 am
 Post subject: water in mast
PostPosted: Sun Jul 22, 2012 3:30 am
boat has been outside all last winter. it is rigged in standard fashion bows forward on trailer. i can hear water inside the mast upwards around the spreader area. i drilled a hole at the lowest point of the mast, (the head/top) and absolutely no water came out. the foot/base of the mast is elevated and facing front on the trailer. do i just wait to raise mast then drill a hole at the base? how is this sealed to allow water half way up but not at lowest point?
eric, sail #205
 Post subject: Re: water in mast
PostPosted: Sun Jul 22, 2012 10:26 pm
Don't drill random holes in your mast. Check for leaks by dunking the mast in a lake and seeing where bubbles are coming from, then seal.
Users browsing this forum: Yahoo [Bot] and 1 guest
