It is currently Sat Mar 25, 2017 9:10 pm
 Post subject: Seized Boom Cleat Clamps
PostPosted: Tue Feb 26, 2013 8:47 pm
Hi Guys and Gals,
Please let me know if you've got a secret to removing broken and seized screws from a boom cleat clamp. I posted pictures in the Repair forum here:
viewtopic.php?f=20&t=46661
Thanks,
Mark
2007 Hobie Tiger
PostPosted: Wed Feb 27, 2013 5:47 pm
I just had the same problem and ended up ordering replacements from Murrays.
Hobie part numbers:
Screws 8031011
Clamp 61711000
Cleat 61070000
If you have access to a drill press you could drill out the screws and insert Helicoils, it's a 10-24 thread. Reassemble with Tef-Gel or Locktite Blue.
Good luck,
Jim
Enjoy every sandwich- Zevon
PostPosted: Thu Mar 07, 2013 8:17 pm
Heat was the trick! I used a propane torch to heat the aluminum all around the broken screw, holding the clamp with pliers. Then I put the clamp in a vise and used a vise-grip to grab the end of the screw and thread it out. It worked great.
Thanks,
Mark
2007 Hobie Tiger
Users browsing this forum: Brett and 1 guest
