It is currently Wed Mar 29, 2017 2:34 pm
PostPosted: Wed Aug 28, 2013 5:30 pm
I have a 2000 SX and the plunger (black thing in spring in rudder casting) keeps peeking OUT of it's hole and gets bent. It appears the cam is rotating to far and allowing it to come out part way. JAMS and will not lock without dismantling it.
The black plunger has done this a few times and finally broke. I didn't have a spare so I tried a H16 WHITE round plunger that fit and seemed like it should work, but really doesn't seem to work well either. I also changed the cam. (To try and stop it from over rotating back which allows the plunger to come up and almost out of it's hole.
I moved the adjustable shim inside the casting all the way forward to lock in the cam. It WASNT enough to allow the cam to pull up when I pull up on the cross bar, so I even drilled (reamed) the slot more forward to get an extra 3/16th more forward motion. STILL doesn't allow the cam to come up unless the tension screw at the bottom of the spring/casting is so loose it's about to fall out. And the water pressure alone would kick up the rudder.
Any idea why these don't seem to be working? I do have a good bit of slop in the rudder in the casting... and a good bit of slop at the top arm mounts to the casting. Could this be part of it? It's REALLY annoying to not be able to lock the rudders down.
IS THE BLACK PLUNGER NEWER OR OLDER than the white one? Or is the black one 18 specific? The white one for the 16?
I have spare white ones is why I ask.
PostPosted: Wed Aug 28, 2013 6:58 pm
The cam is only supposed to go out the bottom?
Tom
Fleet 259, Central Coast CA
H18 ('81)
H18 ('85)
H20 ('97)
H18 ('78)
PostPosted: Thu Aug 29, 2013 4:27 am
Can you post pics?
I'm not really understanding what you're trying to describe here. The plunger is supposed to come out of its "hole" in the casting. The plunger loads in from the top of the casting and pokes out so that it engages the recesses in the cam.
I wouldn't use H16 parts on the H18 rudder system. The plunger and cam are different (note that the cams look the same but have different P/Ns in the catalog, so I can only assume there is some subtle difference between them). If the cam is over-rotating, it sounds like you are not tightening the plunger screw enough.
This sounds like perhaps your rudders aren't drilled properly.
The system does not tolerate slop. Yes, you need to figure out the source of the slop and eliminate it. Slop usually comes from either poorly a poorly adjusted slider plate (cam plate), or mis-drilled holes in the rudder.
The 16/14 uses as round plunger, the 17/18/20 uses a rectangular plunger (side profile).
Try to get some pictures posted.
PostPosted: Thu Aug 29, 2013 4:35 am
I just recently rehabbed my rudder system and found one cam had developed a ridge of plastic where it is supposed to slide past the plunger when unlocking, preventing the cam from rotating even with the adjuster fully imbedded. once I sanded the ridge off and greased the cam and plunger it worked fine.
you may want to check for such a ridge of excess plastic on the cam.
during the rehab I also had to re-rivet one tiller arm to tighten it up,added velcro strips to the lower casting to eliminate rudder flex and slop and a third rudder bushing at the bottom of the lower casting. all these items really took out all of the slop in the system.
as far as I know (at least on my '88), the black plunger is OEM for the H18, it is a square/rectangle shaft with a cylindrical top, unlike the H16 plunger which is a round shaft. there may have been production changes I am unaware of.
hope this helps.
Chris
'88 H18SE Arís
PostPosted: Thu Aug 29, 2013 9:18 am
There have been a few discussions on the H18 style plunger popping out under the cam.
A few possible issues:
A replacement cam screw is loose and has worn the casting which allows the cam to seat too high and allows the plunger to come up out of it's slot.
The casting was drilled with the cam too high and has now worn and exceeded the tolerance.
The casting has a defect in the plunger area (missing material) that allows the plunger to rotate under cam tension.
You should be able to build up material in the lower casting to hold the plunger in column. JB weld maybe? Bondo?
Wouldn't take very much.
PostPosted: Thu Aug 29, 2013 1:34 pm
JB Weld or ALUMINITE to fill any voids or wearing of the rudder casting, because they both have metal properties.
JB WELD® is a 2 part metal filled epoxy
ALUMINITE® is an aluminum powder filled epoxy
Chris
'88 H18SE Arís
