It is currently Fri Jun 23, 2017 4:36 pm
PostPosted: Sat Jun 21, 2014 9:38 pm
I have a 83 H18 that had SX wings added before I bought it. My tramp gave out and I have a new one ready to go on. It appears the rear wing brackets have covered the slot opening where the rear lacing strip is removed and installed.
I searched the forum and some mention of the rear lacing strip being permanent after wings are installed. My rear lacing strip is in poor condition and needs to be replaced with the new Tramp.
I do not want to drill out the rivets. I am thinking of taking a dremel tool to the bottom of the groove and opening it up enough to remove and install the new rear lacing strip. Has anyone else done this? Is there another solution?
Thanks,
Chet
PostPosted: Sun Jun 22, 2014 7:59 am
Drill out the rivets, remove the old strip, install the new one, and re-rivet.
A good tramp should last you 20 years.....
PostPosted: Sun Jun 22, 2014 10:42 am
This rivet gun makes quick work of stainless rivets on our boats! And its cheap!
http://www.harborfreight.com/heavy-duty ... 66422.html
1980 H16
PostPosted: Sun Jun 22, 2014 12:32 pm
+1
Just drill out the rivets, remove the plate, replace the tramp, and re-install. Piece of cake.
PostPosted: Sun Jun 22, 2014 4:43 pm
I ended up using the dremel tool to remove a small section on the bottom lip of the groove. It worked great and I pulled out the old and put in the new lacing strip and it works great.
The new lacing trip has a gap between the end and the gap so no pullout issues.
New tramp is nice, can't wait to get back on the water and give it a try.
