It is currently Tue Jan 16, 2018 5:34 am
PostPosted: Sat Aug 30, 2014 4:20 pm
does anyone have any spare traveler bearings balls (not the cylinders) they'd be willing to sell? Hobie part Mine gave out, and I don't want to do the major surgery necessary to install new cylinders during the season...
thanks,
Steve
1990 Hobie 18SX #2077
PostPosted: Sat Aug 30, 2014 8:29 pm
Murray's marine had some in stock.
Tom
Fleet 259, Central Coast CA
H18 ('81)
H18 ('85)
H20 ('97)
H18 ('78)
PostPosted: Sun Aug 31, 2014 4:45 am
Major surgery? They just pop in.
PostPosted: Sun Aug 31, 2014 5:23 am
They have the balls not the cylinders? I need to replace mine also. I think the balls run smoother than the cylinders.
ADDICTION
1989 HOBIE 18 SE/sx wings
HOBIE ALTER SIGNATURE MODEL
PostPosted: Sun Aug 31, 2014 7:34 am
How? I looked at my crossbar, and it doesn't have an opening ground out on one end to slide them in like some of the older bars. The only way I can see to get the cylinders in is to pull an end cap off the crossbar.
The balls can just be rotated and slipped in without the pins, and then have the pin put in after. to keep them from rotating back out.
Just ordered mine last night- Murrays part 50-61850002
PostPosted: Mon Sep 01, 2014 6:05 am
All crossbars should have the opening machined in the end so you can remove/install the traveler without disassembling the boat. I would use a dremel tool with cut off wheel to cut the opening in the crossbar.
PostPosted: Tue Sep 02, 2014 12:21 pm
If SX... it is under the starboard rear wind anchor plate. You would have to remove the plate.
PostPosted: Tue Sep 02, 2014 1:47 pm
Matt,
I believe you are referring to the slot to remove the rear trampoline strip from the rear crossbar? The traveller track shouldn't be blocked by the wing anchor plate.
Mike
'79 H18 standard 'Rocketman II' sail #14921
PostPosted: Tue Sep 02, 2014 1:49 pm
Sorry Mat you are not correct on this one. The rear wing mount on a Magnum or SX is on the Tramp side (forward side) of the crossbar.
The traveler car removes from the opposite or aft side of the crossbar on the starboard side by the end casting. I've had a dozen 18's from 1979's to 1991, Standards, Magnums and SX. The rear crossbars have all been the same as far as inserting the traveler car.
Look closer at the Starboard side rear crossbar where it meet the casting, its possible that someone has added a slug or screws to stop the car from slipping out.
or
maybe someone has narrowed your boat to close the center tramp lacing gap. ???
91 SX
84 redline Magnum
80 standard Blue Streak
79 standard Red Rocket
81 magnum TBD
Corkguy H18, H20, Tiger
PostPosted: Tue Sep 02, 2014 2:21 pm
99% sure I don't have that cutout (not near the boat today to compare my bar), and the boat is definitely stock width. My crossbars are replacements from 2-3 years ago, so maybe the final batch of crossbars in the warehouse doesn't have that slot cut into the extrusion?
In any event, I'll take the dremel tool to the crossbar to match your photos.
Thanks,
Steve
PostPosted: Tue Sep 02, 2014 4:38 pm
My guess would be they simply forgot to add the opening. There were quite a few issues with boats/parts as they did some of the "last runs." With the boats out of production or on limited production runs, a lot of the "tribial knowledge" in the manufacturing process gets lost and steps get missed.
Grind it out with the dremel and you'll be good to go.
Users browsing this forum: Bing [Bot] and 1 guest
