It is currently Mon Feb 18, 2019 12:44 pm
 Post subject: Hobie 18 gooseneck
PostPosted: Mon May 28, 2018 12:03 pm
Having trouble with a missing gooseneck for h18 boom. Does a 16 goose neck crossover? Visuals help out a lot. Got a h18 tha5s been neglected and making repairs to sail it. Thank you
Sent from my SM-G950U using Tapatalk
 Post subject: Re: Hobie 18 gooseneck
PostPosted: Mon May 28, 2018 8:44 pm
No h16 booms have a fitting that goes in the mast track. h18 just has a post with a hole in the end that you pin to the mast fitting
'82 NACRA 18 Square
'85 Hobie 18 "Honey Badger Don't Care"
'86 Hobie 18 "The Rippin & The Tearin"
PostPosted: Mon May 28, 2018 9:33 pm
Thank you been a while for me and an 18 I was told I could have it as long as I restore it ImageImage
PostPosted: Tue May 29, 2018 9:04 am
Just to clarify, there is a hinge fitting that goes between the "post" on the boom and the mast fitting (shown on page 15 of the assembly manual). If you were to pin the post on the boom directly to the mast fitting, you would almost certainly break the gooseneck.
https://static.hobiecat.com/digital_assets/H18%26SX_Manual.pdf?_ga=2.139414515.1740873645.1527609468-2078875715.1490016879
PostPosted: Tue May 29, 2018 11:47 am
Congrats on the H18!
If you have a local dealer, they may have a vertex in stock... otherwise Murray's has them in stock and upgrade form:
https://www.murrays.com/product/50-50772031/
https://www.murrays.com/product/12-4060/
Randii
PostPosted: Tue May 29, 2018 12:13 pm
The gooseneck pin is readily available from any Hobie dealer. To replace it, you'll need to drill out the rivets in the end of the boom, remove the cap, install the new gooseneck, and then re-rivet the end cap to the boom. http://www.backyardboats.com/mm5/mercha ... e=10772010
The gooseneck yoke http://www.backyardboats.com/mm5/mercha ... e=60710000 and the vertex http://www.backyardboats.com/mm5/mercha ... e=50772031 are both also readily available, if you need them.
Mike
'79 H18 standard 'Rocketman II' sail #14921
