srm wrote:
broken08 wrote:
and this causes the round stem of the plunger to break half off the half cylinder top.
As I mentioned in my prior post, the H16 uses cylindrical plungers. The 18 plunger is rectangular (at the top). Are you sure hou have the correct plungers installed? H18 plunger should look like this....
Otherwise it sounds like maybe your cam is over-rotating on release allowing the plunger to pop out. Are you sure you have the cam installed correctly and is it in good condition?
Yup, that's them. I just put in a new one too. I greased it all up. New cam and sister screw seem tight. We just bought these rudders like 7 years ago and only have like 15 hours or so on them. Stored the last 5 years then suddenly they aren't working right.
Side note; I can't find anything that shows the normal function of the cams (like which way they should be to start, how they rotate, proper way to engage them,etc.) or any instructions on how to adjust the striker plate that goes in to them. I'm sure they are out there but I can't find it.
If anyone can make a quick video showing how they are supposed to work, it would help a lot!
