Joined: Tue May 27, 2003 12:44 pm Posts: 15036 Location: Oceanside, California
360 MirageDrive Adjustments
Proper cable adjustments are required to prevent premature wear and damage to the 360 MirageDrive. Adjustment of the Global Adjustment Screw and the Idler cable will keep the pedaling loads even on all cables.
The Global Adjustment is accessed through a hole in the bottom of the drive and is for tensioning the internal lines inside the Drive. The Idler Cable connected the left and right pedal and is a stainless steel cable coated in protective black plastic tube housing.
A loose idler cable can cause the forward internal cables to be overloaded. This may also cause a clicking sound from inside the drive. View this short how-to video for proper tensioning adjustments.
A quick how-to for adjusting the MirageDrive 360:
_________________ Matt Miller Former - Director of Parts and Accessory Sales Warranty and Technical Support Hobie Cat USA (Retired 11/7/2022)
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum
