It is currently Fri Jul 10, 2020 2:45 am
 Post subject: Compass Rudder Upgrade
PostPosted: Tue Apr 09, 2019 8:46 am
I tried searching but so far haven't found anything regarding a bigger rudder for the compass. I tested out a camo compass and while the rudder was enough for regular use it didn't inspire confidence that it would work for sailing or rougher conditions. I did figure out it doesn't turn at all when the rudder isn't deployed. I found that out pretty quick. But I'm going to buy the sail kit and I noticed the compass rudder is a bit different from the old upgraded "sailing" rudder. So if anyone of you have an insight I would very much appreciate it.
PostPosted: Thu Apr 11, 2019 9:44 am
I made this procedure on the new Outback 2019, but this rudder blade can also be put on Compass.
I've adapted big rudder blade from Pro Angler :)
Sent from my iPhone using Tapatalk Pro
PostPosted: Thu Apr 11, 2019 11:44 am
Great idea! 8)
PostPosted: Wed Apr 17, 2019 9:44 pm
Fantastic! Thank you.
PostPosted: Mon Jun 24, 2019 9:28 pm
Does anyone know how to remove compass rudder? Not sure if it's similar to the new Outback but it's different than the PA.
PostPosted: Fri Oct 11, 2019 6:54 am
[quote="johnnybravo"]I made this procedure on the new Outback 2019, but this rudder blade can also be put on Compass.
You rocks bro. Absolutely amazing! 8) 8) 8) 8)
Liftmaster MT5011U Review
