It is currently Wed Jul 15, 2020 9:41 pm
PostPosted: Sun Jun 21, 2020 6:40 am
I updated my H16 Jib Halyard to the latest Amsteel single-braid Dyneema and have a couple questions (I'm unfamiliar with the new high-tech lines). I'm asking because I've read Dyneema likes to slip:
(1) what's the appropriate knot to secure to the becket on the lower block? (I'm using a bowline and it seems holding Ok so far).
(2) any advice on tying off the jib halyard on the mast horn cleat? (Was out in big air and the usual "around, figure 8, and hitch" I have used for years with other lines slipped all the way until the forestay was tight).
Thanks for any advice!
-Daniel
H16 2002 Islands
H14T 1991
PostPosted: Mon Jun 22, 2020 6:10 am
Your experience mirrors mine and is common I believe. Totally sucks.....especially in a distance race with plenty of air.....when the halyard loosens, the jib luff bends off, and you can't sail to weather worth a darn.
I've been using a bowline on the becket as well and it has worked fine. Can't remember if I did, but you could always put a simple overhand knot in the bitter end to act as a stopper for it slipping out.
When cleating it off, I make sure to overlap the first couple of wraps with the next available ones, keeping it very tight the entire time (otherwise it can slip while you're still wrapping). After about six or seven wraps, friction takes over....a couple of figure eights and hitches and you're good.
Jerome Vaughan
Hobie 16
PostPosted: Mon Jun 22, 2020 8:32 am
Thanks RnH... I'm suspecting just needed more wraps around the horn. Next time I'm out I'll try that. It's damn slippery stuff.
I'll stick with the bowline but expect to have to keep an eye on it.
I've heard Dyneema is easy to splice... maybe if I have a couple down days I'll try to splice in the lower block just for the hell of it.
H16 2002 Islands
H14T 1991
PostPosted: Tue Jun 30, 2020 3:38 am
Update: I re-tied the halyard to the becket with a “water bowline”. Essentially a double-bowline. Seems ok. I did some research and the consensus is a “modified water bowline” doesn’t slip. May try that once I get some practice.
For the mast cleat, did several wraps and 8s and then tied off. Didn’t skip in moderate wind. Next big air day will be the test.
H16 2002 Islands
H14T 1991
