It is currently Sat Mar 25, 2017 7:26 pm
 Post subject: 1981 H16
PostPosted: Mon Oct 11, 2004 1:16 am
I am looking at buying my first 16. The one I found seems solid. Hulls are solid. With my inspection I can see day light shinning thru the fiberglass along the bottom of the hull, is this normal? where the rudder mounts to the hulls are craked is this a easy fix? I think fiberglass repair and installing gudgeons are in order. Please Advise.
Thanks Todd Christian
8)
PostPosted: Mon Oct 11, 2004 8:04 am
Hi Todd- you are certain to get a lot of replies from the many repair oriented persons here.
Would you clarify how you noticed ...."day light shinning thru the fiberglass along the bottom of the hull" - I'm thinking that you looked through deck ports correct? If so, yeah, that is pretty normal from beaching, and easily attended to- look around the forum for tips on building up the keels.
And have a Hobie day! 8)
 Post subject: LIGHT SHINING
PostPosted: Mon Oct 11, 2004 11:05 am
Yes the inspection was with deck port and the drain plugs. Is there any thing else I truley need to look at I want!!! This CAT!!! The Seller is not a Hobie sailor I have worked out that I want to take her out before a final price can be reached. I just don't want a 16 foot piece of driftwood.
Todd
"IF there is no wind row."
PostPosted: Mon Oct 11, 2004 5:08 pm
If, when you say the hulls near the rudders are cracked, you mean this:
then I'm pretty sure that's just cosmetic. To "fix" it I just mixed up some epoxy and dribbled it around the cracks and smeared it on the inside of those holes.
Warm regards,
Jim
"A little crazy but with big balls."
 Post subject: Cracks
PostPosted: Mon Oct 11, 2004 9:23 pm
FANTASTIC! :!: I will get out the sony digital in the morning and let you have a see, I think she will clean up nice. thanks for the advice.
Todd
IF THERE IS NO WIND ROW
Users browsing this forum: Yahoo [Bot] and 4 guests
