It is currently Sun Jan 21, 2018 7:32 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Hobie 16 FAQ
PostPosted: Fri Jun 05, 2009 11:05 am
Specifications
Length: 16' 7"
Beam: 7' 11"
Mast Length: 26' 6"
Sail Area: 218 Sq. Ft.
Weight: 320 lbs.
Hull Construction: Fiberglass/Foam Sandwich
H16 Owners Manual: http://static.hobiecat.com/digital_assets/H16_Manual.pdf
Hobie 16 Parts Guide: http://static.hobiecat.com/digital_assets/H14-16_Parts.pdf
Support Pages: http://www.hobiecat.com/support/index-sail.html
Rigging Video
The following video was produced in the late 80's, but has some good information that pertains to all vintages of Hobie 16s. Jib halyard systems, sheeting systems have changed a number of times over the years. This video addresses the configuration at that time.
PostPosted: Tue Jun 16, 2009 11:24 am
Hobie 16 mast step replacement.
This was written up in the Hotline (starts on page 14):
http://static.hobiecat.com/2010_archive/hobieclass/eHCA_News01_02-05.pdf
PostPosted: Wed Mar 24, 2010 1:35 pm
Recent Hobie 16 trampolines have an added grommet at the rear corners. The following sequence shows proper lace routing.
Rear lacings start at the outboard sides of the rear castings.
Finish off with half hitches in the center rear area. The example shown has routed the lines back (doubled over) to use up excess line.
PostPosted: Tue May 20, 2014 1:47 pm
On a 14 or 16 you can "pre-bend" the sidebars before tensioning the center lace. We do not use double grommets down the center and get tight tramps without a huge effort.
Use the mainsheet system. Lay the blocks and line on the tramp "unsheeted" from side to side bar... in the center. Add a line to the base of the blocks that can reach around the sidebar, under the tramp and meet the top block. Tie off. Pad the side bars with some cardboard where the line goes around the sidebars. Sheet the system to bend the sidebars in by over 1". We sheet till the tramp gets a little pucker shape along the sidebar. Cleat the blocks and tighten the tramp using moderate tension. Using the vise grips, dowell or just holding the line at each grommet as you go. Tension the aft lace last and then release the block set.
We use this system and get over 1-2 inches of prebend in the bars for over 1 inch after releasing.
Worst loads on a grommet are during tensioning each one... this saves effort and grommets.
Users browsing this forum: Bing [Bot] and 3 guests
