It is currently Mon Jun 26, 2017 4:16 am
 Post subject: How should I do this?
PostPosted: Sat Oct 16, 2004 6:27 pm
I have this 2 part paint.. some sort of base, then the paint, I was told to spray on this base first let it dry then paint the boat.. its made for our h16's I bought it at a hobie dealer in Austin texas. should I gelcoat first or will this paint give me a finished look when it dries..?
PostPosted: Sat Oct 16, 2004 10:12 pm
Two part paint? I always understood that a two part paint is, two parts mixed together to make the paint. Usually the pigment and the drying agent.
I seriously think you need to do some more research with whoever sold you the paint. If you are unsure of what to do, do not do it. It can become a nasty experience, and a real pain in the butt to repair.
PostPosted: Sun Oct 17, 2004 8:29 am
No.... its a one part paint.... It's a Pre-Coat Primer for polyurathane paint, then you put the polyurathane paint, no mixing... it supposed to seal and bond and give a little extra strength.
PostPosted: Sun Oct 17, 2004 8:30 am
Do you know how many access ports the h16 can structurally take? 2 or 3 per side or just one?
PostPosted: Sun Oct 17, 2004 7:53 pm
AAAHHHHH!! OK! yep that is what I did to my boat. Painted her with poly. I love the finished product, although the paint I used was a two stage paint.
I did apply a light coat of primer, sanded her down to smooth the coat off. Then applied the polyurethane coat. Like three to four coats actually.
http://www.sefl3s.com/ebay/hobie/001.JPG
http://www.sefl3s.com/ebay/hobie/002.JPG
http://www.sefl3s.com/ebay/hobie/003.JPG
http://www.sefl3s.com/ebay/hobie/004.JPG
http://www.sefl3s.com/ebay/hobie/005.JPG
http://www.sefl3s.com/ebay/hobie/006.JPG
http://www.sefl3s.com/ebay/hobie/007.JPG
PostPosted: Sun Oct 17, 2004 8:13 pm
Robi, what kind of hull work did you do before you pianted it?
I have such delamination that i pretty much had had to poke holes on average every 3 inches accross the top and sides of my pontoons, I have one nearly finished and it is turning out to be rock hard.
PostPosted: Sun Oct 17, 2004 8:39 pm
what kind of paint did you use on your frame and corner pieces? and does it hold up pretty good in the water?
PostPosted: Sun Oct 17, 2004 9:46 pm
All the paint used is poly-urethane. All the paint has helled up great in the conditions. As far as hull work all I did was put some epoxy on the bottom of the hulls. Rough up the gelcoat, prime and paint.
As far as soft spots, there are NON on this boat. I guess I am just lucky. She is a 83 and extremely dry, hard and stiff.
Oh she is still for sale. :D
PostPosted: Mon Oct 18, 2004 9:25 am
Dood those are awesome pics! I can't believe you're selling that thing after all your hard work.
BTW... how much did paint and supplies run you? :oops:
Warm regards,
Jim
"A little crazy but with big balls."
PostPosted: Mon Oct 18, 2004 9:37 am
LOL :lol: You are kidding right!!! :shock:
hahahahahhaha :P :P :P
Users browsing this forum: Bing [Bot] and 1 guest
