It is currently Tue Jul 23, 2019 6:21 pm
PostPosted: Fri Aug 21, 2009 3:26 pm
There is a bolt that holds the metal part of the mast to the fiberglass part. ( I assume it's fiberglass or some non-conductive material) Mine is missing and I can't seem to locate it on the Hobie part diagram. is this something I can buy and if so where?
PostPosted: Fri Aug 21, 2009 3:32 pm
The original 1985 CompTips had a bolt. That is no longer available. You can use anything there. Should be epoxied in place at the minimum and bolted / riveted.
PostPosted: Fri Aug 21, 2009 7:44 pm
thank you
PostPosted: Fri Aug 21, 2009 8:41 pm
I have one of the early comptip on my stars and stripe h 16 and it has what looks like an end to end polt such as the one that comes in the rudder cam rebuild kiy only larger. I make sure that i check it before everytime i go out on the water
PostPosted: Fri Aug 21, 2009 8:42 pm
I have one of the early comptips on my stars and stripes h 16 and it has what looks like an end to end bolt such as the one that comes in the rudder cam rebuild kit only larger. I make sure that I check it before everytime i go out on the water
PostPosted: Fri Aug 03, 2018 2:18 pm
Can anyone give the specs of the bolt that was originally installed in the 1985 Comptip mast? Length size type ? Believe it was a sex bolt?
PostPosted: Fri Aug 03, 2018 2:22 pm
Was a sister screw... flat head on each end. One long clear through was female threaded. Then a short standard flat head screw. I don;t have the specs.
Better to glue in place with epoxy and add some stainless rivets for good measure.
