clend692 wrote:
That helps tremendously, you explained it well enough that I don't think I even need a pic! Thanks!
One thing, then, I am still confused... If i have a single trapeze and I am sailing with someone, should that person trapeze out in front of the shroud?
Then if I am by my self, and I try to trapeze, I stay to the back of the boat behind the shroud, is that right?
Thanks again!
It's usually easiest for the crew to go out from behind the shroud, then move forward if they need to (lighter air, flatter water).
Unless you have an extra-long tiller (like from a 17), then the driver is limited to how forward they can get by the length of the tiller and their arms.
Fore/aft weight placement is usually "as far forward as you dare, without pitchpoling". You trap further back in waves to keep the leeward bow from digging into waves.
