It is currently Sun Jan 21, 2018 7:43 pm
 Post subject: 6:1 blocks
PostPosted: Tue Jun 17, 2003 5:04 pm
when you hook up the 6:1 blocks do you use the for or aft hanger on the boom or does it matter
PostPosted: Tue Jun 17, 2003 5:31 pm
Hobie Tech / Moderator
Pretty sure you use the rear hanger so that the sheets are at an angle to the x-bar and not hanging straight down. By doing this, when you sheet in tight on the main it pushes the boom forward and helps to rotate the mast.
 Post subject: 6:1 BLOCKS
PostPosted: Tue Jun 17, 2003 5:52 pm
THANKS FOR THE REPLY
Users browsing this forum: Bing [Bot] and 1 guest
