It is currently Wed Jan 17, 2018 3:01 am
 Post subject: Mast Base Adhesive
PostPosted: Sat Jul 02, 2005 5:12 am
I have to replace the mast base. Do I need to use some sort of adhesive in addition to riveting? If so, what type of adhesive should I use.
Also, I had to replace the cheek block on the mast. When I removed the rivets, the inside part of the rivets fell through the holes and are now rolling around inside the mast. I don't really want to break the seals on the mast to get them out. Is this going to be a problem in the future?
Thanks,
Joe
PostPosted: Sat Jul 02, 2005 7:40 pm
Short answer to both questions:
No. :D
On #2 it's no only if you don't mind the rattle.
PostPosted: Sun Jul 03, 2005 2:29 pm
Maybe he can switch masts with Jerome "Rattle 'n' Hum" Vaughan. :D
Warm regards,
Jim
PostPosted: Tue Jul 05, 2005 10:55 am
Rivets... No they will move around inside the mast (especially when you step the mast). They will not cause any issues.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
