It is currently Sun Jan 21, 2018 1:38 am
PostPosted: Tue Aug 25, 2009 5:30 pm
Hi all,
I have a 1979 Hobie 16 with 5:1 Seaway mainsheet blocks, and I am unsure of how to correctly reeve them.
Here is a diagram of the blocks. I would really appreciate it if someone is able to draw on it with step-by-step arrows showing how to reeve it. And the icing on the cake would be if someone could explain the general principles for how to figure out how to reeve blocks.
In order to avoid any questions about ignoring prior posts, I already looked at this one:
https://www.hobiecat.com/community/view ... =14&t=7720
But even the definitive image (link below) is unclear to me - I can't tell the order in which it is threaded.
http://www.swimmerhouse.net/blog/media/ ... yblock.JPG
Here is my diagram of the blocks:
Broward County, FL
1984 Hobie 16, Olympic Edition (kept in NY)
PostPosted: Tue Aug 25, 2009 8:02 pm
Becket of aft upper block to aft side of double block (doesn't matter which side)
to aft side of forward single block
to forward side of double block (side you didn't use before)
to forward side of aft upper block
to aft side of ratchet block.
PostPosted: Wed Aug 26, 2009 3:35 am
Thanks MBounds!
What are the general principles for figuring out how to reeve blocks correctly?
Broward County, FL
PostPosted: Wed Aug 26, 2009 9:07 am
perhaps this may help???
http://www.waldorfs.com/block6.JPG
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Mon Jan 09, 2012 6:57 am
I always thought it was a 4:1. 4 pulleys and the 1 at the end with the break.
PostPosted: Wed Jun 27, 2012 6:52 pm
thanks
Waldorf your picture is the best should be able to reeve it with that.
may fair wind blow upon you.many thanks
PostPosted: Thu Jun 28, 2012 7:30 pm
Paris wrote:
Thanks MBounds!
No crossovers.
Users browsing this forum: dave202 and 3 guests
