It is currently Sun Nov 19, 2017 5:07 am
 Post subject: rudder cam alternative?
PostPosted: Mon Apr 22, 2013 6:09 pm
Okay, so my new (to me) 1981 Hobie 16's rudders have a machined piece of billet alluminum in place of the rudder cam. I've seen the cams in my buddies 1983, and my set up is nothing like his. My top casting piece is bolted to this aluminum piece where his has the adjustment screw on top. So this aluminum piece pivots there and where its rivoted in the bottom casting (where normally the cam would be). It all opperates the same as the regular system. Lift up and push back to drop the rudders, lift up and pull they come up. Even without the spring system they stay down unless they are given a decent amount of resistance (I.e. Running aground).
Is this something people have seen before? Has this ever been factory? I just don't know... I'll try and get some pictures of the situation. Sorry for my terrible discription. Thanks in advance for any help.
A smooth sea never made a skilled sailor.
Tim (WI)
1981 H16
196? Alcort Catfish
1976 Catalina 22
PostPosted: Tue Apr 23, 2013 2:09 pm
Congrats on your Hobie - you'll have a ton of fun. Someone may know your setup but pix may help. viewtopic.php?f=18&t=8574
Jonathan
'85 H16 __/) 87468 Tidal Wave
PostPosted: Tue Apr 23, 2013 4:30 pm
Alrighty. I've got some pictorials...
Tim (WI)
1981 H16
196? Alcort Catfish
1976 Catalina 22
PostPosted: Tue Apr 23, 2013 8:06 pm
Can't wait to hear this one explained.
Jonathan
PostPosted: Tue Apr 23, 2013 8:18 pm
I know, right!? It functions just as well as my buddies cam setup, if not tighter(less slop)... I do know the original owner raced it for most of its lifetime. But I'd really like to know if anyone else has ever seen this before...
Tim (WI)
1981 H16
196? Alcort Catfish
1976 Catalina 22
PostPosted: Wed Apr 24, 2013 8:18 am
Rudder cam video from you tube...
http://www.youtube.com/watch?v=7jfn8f93XiQ
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Wed Apr 24, 2013 12:14 pm
Great video waldorf but el_gato_loco is looking for tips to ID these metal cams as they do not appear to be the plastic rudder cams we are used to seeing.
Jonathan
PostPosted: Thu Apr 25, 2013 3:30 am
Its definitely a custom setup.
PostPosted: Thu Apr 25, 2013 6:34 pm
:o
PostPosted: Thu Apr 25, 2013 7:31 pm
Tom King wrote:
:o
Yeah, I know... Any thoughts?
Tim (WI)
1981 H16
196? Alcort Catfish
1976 Catalina 22
PostPosted: Fri Apr 26, 2013 2:58 am
el_gato_loco wrote:
Any thoughts?
If it works, go with it. I don't see any permanent changes made to the castings, so you could always switch it back if you want.
PostPosted: Fri Apr 26, 2013 4:02 am
srm wrote:
el_gato_loco wrote:
Any thoughts?
My thoughts exactly
Thanks guys!
Tim (WI)
1981 H16
196? Alcort Catfish
1976 Catalina 22
PostPosted: Sat Apr 27, 2013 12:54 pm
If it works really good for all things they are needed for, it will be well worth close examination of the design. Rudders need to be easy to lock down, and kick up, but stay locked down while sailing in any conditions. I've never had any problem operating, and maintaining the stock design, but cams do wear out.
