It is currently Mon Mar 27, 2017 8:35 am
PostPosted: Wed Mar 31, 2004 7:30 am
Last fall I bought an 1980 16. One thing I noticed was is had over 300 little bumps all over the sides of the hull. Knowing I needed to do some work I felt OK. Now, I';ve had the boat stored inside for the past 5 months with the drain plugs removed. This past weekend as I was sanding down the finish, some of the bumps turned into holes in the glass and some disapeared by sanding the gel coat. As I worked my way down the hull and then looked back at my work, I could see water seaping from the nice finish, where the bumps had been.
My question is, do I now need to sand off all of my gelcoat from the hulls and seal the fiberglass? I know if I just finish and paint that I will get the bumps back and may have leaks.
Any help would be gladly taken.
Buxton
PostPosted: Wed Mar 31, 2004 7:38 am
Do a Google search for "repairing fiberglass blisters"
Here's a good article that came up:
http://www.boats.com/content/default_detail.jsp?contentid=1899
You've got a lot of work to do . . .
