It is currently Tue Mar 28, 2017 7:41 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Oct 01, 2010 8:08 am
I'm trying to make (and hopefully maintain) a list of year-to-year changes in the Hobie 16. From reading a lot of past threads and doing a lot of searches, I've come up with the following list but there are definitely some omissions and likely errors. Please post corrections to this thread if you have them and if you have pictures to document a specific change you can send them to me (anton at largiader dot com) and I will work them into an improved article.
I will edit this post to reflect new information as it becomes established. Here's what I have for now, and than you to the people from whose posts I've harvested this information:
Original main traveller car was sliding metal plate
Original mast step with hook
Early '70s - mast step or base changed to remove hook
1972 - main traveler with rollers
1982 - Shorter shrouds, longer forestay, modified mast step casting to allow for more aft mast rake.
1984 - weight reduction 340 to 320, red adhesive
1985 - Comptip and main halyard, reef points removed from main
1983 or 1984 Adjustable rudder castings
Mast step changes & mast rake - early 1970s, 1982, 2003. Which of these affected the base casting and which affected the step casting?
mid-'80s flush boom vang fitting and then removed
mid-'80s clear anodizing ended
1995
- shrouds shortened from 19'2" to 18'11"
- Updated corner castings (injection moldings) and trackless pylons. Is this when the jib traveler blocks were integrated also?
- main traveler integrated into rear crossbar
- integrated jib traveller track with cleat on pad riveted to crossbar. Delrin sliding car
- Hobie 20-style tiller connectors
1996? - deeper jib traveler track with brass-wheeled car
mid-late '90s - updated bolt rope in sails
2000 - recut jib?
2004 - another mast step casting change to improve rotation
2005 - roller bearing jib traveler with cleat on car
2009
- shrouds shortened slightly to 18' 10.25"
- bridle lengthened to 3' 9.5"
Unknown:
- 6:1 main
- Aussie jib halyard system
- Double trapeze
- Trapeze adjusters and "Can't Miss" handles
- Coated wires
- EPO2 Rudders
- One-piece, cast gudgeons
- Adjustable batten end caps
- Double-grommeted trampolines
My Hobie 16 pages
PostPosted: Wed Jun 12, 2013 6:53 pm
Im interested in knowing many of these unknown years. Anyone know any of this history?
Zach
PostPosted: Thu Jun 13, 2013 7:55 am
My 81 hobie does not have the adjustable rudder castings, but my 83 does, that that takes care of that.
PostPosted: Thu Jun 13, 2013 7:59 am
My 82 didn't have adjustable rider castings. So that means that started in 83.
Zach
PostPosted: Thu Jun 13, 2013 4:19 pm
Integrated Travelers on the front and rear crossbars started mid-year in 1994. However they are both shallow tracks. The rear track became deep in 1995. Not sure when the front changed.
Garrett
94' H16 - 114050
https://www.facebook.com/groups/423463424425838/
PostPosted: Thu Jun 13, 2013 4:21 pm
Other changes missing from the list:
- Straight tiller arms. 83-84 ish???
- Stock boats with Jib trim kits / cheek block integrated in the front castings - ??
Garrett
94' H16 - 114050
PostPosted: Thu Jun 13, 2013 4:26 pm
Thanks for the activity on my ancient thread. :) Much of it was gleaned from posts here, but they may not be definitive. For instance, there was recently a thread on rudders where it was suggested that the tiller arms changed when the rudder castings changed, and that is generally considered to be 1984 although the cut-offs never seem to be very sharp.
Keep the info coming!
My Hobie 16 pages
PostPosted: Thu Jun 13, 2013 5:23 pm
my 83 still has bent rudders. so it must have been 1984.
PostPosted: Sun Sep 15, 2013 1:33 pm
I'll see if I have any of the old dealer bulletins. I do remember the tiller arms were changed to straight so that the mast could ride on the rear crossbar, and not the tiller crossbar when trailering. I still have some of the bent arms only. I liked the bent arms.
PostPosted: Sun Sep 15, 2013 4:27 pm
I have since seen several boats with straight arms and old castings. The arms definitely changed first.
My Hobie 16 pages
PostPosted: Mon Sep 16, 2013 12:17 am
I have a 2003 and the jib traveller blocks are not integrated.
This is of course assuming the front cross bar is still original.
PostPosted: Mon Sep 16, 2013 6:50 am
Odd...my 2002 has integrated jib tracks.
Zach
PostPosted: Mon Sep 16, 2013 9:59 am
That would be an incorrect assumption.
Integrated travelers were brought to the US in 1995 (they were introduced in Europe prior to that).
PostPosted: Mon Sep 16, 2013 9:04 pm
The actual track is integrated it is just the blocks on the corner castings are not, they are riveted on top.
PostPosted: Tue Sep 17, 2013 4:35 am
The castings must have been replaced at some point, since the integrated track / integrated blocks in the castings were introduced together.
