It is currently Thu Nov 23, 2017 6:42 am
PostPosted: Wed Sep 07, 2011 11:32 am
Baby or full size?
My mast fills with water faster than the Titanic. Numerous sealing efforts have been to no avail.
A mast head float is what I seek. I know of a Baby Bob for sale I am unsure if that will do the job.
PostPosted: Wed Sep 07, 2011 11:37 am
A mast float will not solve your leaking mast problem. I have the baby bob and my mast floats, works great. If your mast leaks, you'll need a hot air balloon instead.
Where is your mast leaking from? People here might be able to tell you how to address it if you tell us where it leaks.
Marc...
PostPosted: Fri Sep 09, 2011 6:02 am
Baby bob is the right model, but you need to resolve your leaking mast, obviously.
'81 H16
PostPosted: Fri Sep 09, 2011 7:59 am
Put the mast in a pool or lake to find where it leaks.
If it leaks from the top or bottom of the mast, one of the mast end foam plugs (one at each end) will need to be sealed. You would need to remove the mast base or mast head. I would think filling the area with expanding foam would seal it.
If it leaks around any rivets, you can seal with silicone or better yet replace the rivet using ss rivet w/ a casing.
1979 Hobie (sold)
1981 Hobie 16 Tequilla Sunrise - still own
2008 Hobie 16 (currently sailing the crap out of this boat)
1977 Super Sunfish
John
