It is currently Mon Jan 22, 2018 7:07 pm
PostPosted: Thu May 03, 2012 2:38 pm
Does anyone have a picture of the correct way to thread a line through a 6:1 down haul?
Thanks!
PostPosted: Fri May 04, 2012 12:19 pm
Although the factory picture is this:
The best way to do it is like the 6:1 low profile mainsheet. Turn the top block 90 degrees to the bottom.
PostPosted: Fri May 04, 2012 12:28 pm
I just went through the same debate with my on mine.
I ended up doing it like the factory picture because I didn't come up with enough room at the goosneck for the upper block to be able to twist 90 degrees.. Although there is no need for it to be able to go block to block...
Was I missing something?
www.thehobiewayoflife.com
PostPosted: Sun May 06, 2012 11:14 pm
Beautiful! Thanks!
