It is currently Fri Mar 24, 2017 9:17 am
PostPosted: Thu May 24, 2012 8:16 am
When did the styles change? Why did they change? Anybody know? Mine are strait on the 1989. They rub against the deck when the rudders are up. (Trailering)
PostPosted: Thu May 24, 2012 4:03 pm
They changed in 1984 when rake adjustable castings were introduced.
Your tiller arms are not the problem. The castings could be worn, the top hole in the rudder is in the wrong place, the rudder pin is sloppy - could be a lot of things.
The short term fix is to tie the tiller arm / tiller crossbar connection to the rear pylon with bungee while trailering.
If you don't have the 20-style tiller connectors, make sure the nut end of the tiller connector is pointing up so it doesn't scratch the deck.
PostPosted: Fri May 25, 2012 5:44 am
Thanks, I know there is slop in the system. I'll track it down and rebuild. Also the castings are worn. I will have to weld up the worn areas until i get the proper position.
PostPosted: Fri May 25, 2012 12:08 pm
Try the hobie cat plastic inserts in the castings and some quality SS rudder pins maybe re rivet tiller arms while there new cams springs and plunger don't forget sister screws maybe the new style gungeons that are one piece
Former Hobie Admiral Gary
also get a new tiller bar to crossbar connector kit
Users browsing this forum: Bing [Bot] and 4 guests
