It is currently Sat Jan 20, 2018 2:24 pm
 Post subject: rolling furler
PostPosted: Thu Jul 12, 2012 3:29 pm
I want to hey to everyone ,I ve only recently found this site.
My question is I was given a furler kit for my 16 .The thing is how do you adjust the downhaul on the jib now ? I assume the stay adjuster.but what hole of the forestay adjuster do I attach the jib too.
It seems the jib halyard should be tight.Any way I hope this makes sense.
 Post subject: Re: rolling furler
PostPosted: Thu Jul 12, 2012 4:48 pm
In order to use the furler, you must have the roller-furling jib. It does not work with the stock jib.
PostPosted: Thu Jul 12, 2012 8:31 pm
The standard Jib works well with my Hobie Furler... I just took the battens out...
It flaps around a bit at the leach and i have made plans to cut it down but just haven't got around to it.
You don't use a halyard.. just attach it to the forestay ... nice and tight... but with enough slack to get some mast rake....
Here is a vid of last sundays fun...you can see it in action... you do lose a bit of performance but for me being able to power down quickly at the beach is a big plus....
http://www.youtube.com/watch?v=FgGN-pKFSE4
i will post the different sail cut soon....
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Thu Jul 12, 2012 8:42 pm
Hippster....the pic is at the bottom of this post
https://plus.google.com/photos/10526906 ... 6Lzls_YgAE
PostPosted: Fri Jul 13, 2012 4:29 am
We obviously have a different definition of "work". "Flaps around a bit" = flog to death in my book. It's pretty much all you hear in the video. It's really bad for the sail and will significantly shorten its life.
An older sail would not stand up to that kind of abuse for any length of time.
PostPosted: Sun Jul 15, 2012 3:43 pm
Matt... sound like i should get that jib cut down soon... What other elements are different in the real Hobie furling jib????
PostPosted: Tue Jul 17, 2012 10:44 am
When I bought my boat, the jib did not have battens. The previous owner sailed it that way and there was a small rip in the sail right above the clew plate from the flapping.
I got a loft to fix it and added battens.
Marc...
Users browsing this forum: jclarkdawe and 1 guest
