It is currently Tue Jun 27, 2017 5:29 pm
 Post subject: reefing the main
PostPosted: Fri Aug 10, 2012 10:37 am
:oops: :?: :?: what do the terms "reef the main mean?
 Post subject: Re: reefing the main
PostPosted: Fri Aug 10, 2012 12:55 pm
Reefing is shortening the sail to depower the boat. In strong and/or gusty winds it is easier to control most sailboats with less sail up. That said I have not see any H16 sails that have reef points in them since the early 80's.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Fri Aug 10, 2012 2:52 pm
My '85 boat had reef points. It was in '85 that Hobie brought out the comptip mast and eliminated the reef points. It did so because, to be able to reef, you needed the longer wire in the main halyard. That defeated the purpose of the comptip by making a metal connection from the top of the mast past the comptip to the metal part of the mast.
Howard
PostPosted: Fri Aug 10, 2012 3:27 pm
I have 2 sets of sails one an 84 the other an 81,both have the gromets.Do you lower the main until the gromets are at the boom and tie them off with rope?
PostPosted: Fri Aug 10, 2012 4:46 pm
I think i figured it out ,there are 2 stop sleeves on the main halyard,do I use the lower one on the mast hook, then I assume I tie off lose sail to the boom ??
PostPosted: Fri Aug 10, 2012 5:21 pm
Yes. However, be very careful how you tie off the middle grommets. You do not want them tight to the boom. The only reason they are there is to help contain the bunch of sail. You want the middle grommets loosely tied to the boom. You want the reef point at the mast (luff) to be very tight since this is how you will tension the luff of the sail. You want the grommet at the aft end of the boom (leech) to be tight as well. Just to verify the sail can handle the stress from reefing look at the luff and leech grommets to see if they are reinforced properly.
Also, you still need good sail shape so do not forget to tighten the outhaul and the luff properly. If you need to reef you are probably going to want a flatter sail.
Nick
Current Boat
In the market
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Fri Aug 10, 2012 6:21 pm
Thanks nick ,that answers my question
PostPosted: Mon Aug 13, 2012 4:37 am
For the middle grommets, I use bungee cords with ball ends like this:
Marc...
PostPosted: Wed Aug 15, 2012 9:35 pm
Perhaps you could take one of your sails and cut it down for the bigger winds...
I used this sail for the first year i sailed to give me a little confidence when soloing in the ocean....
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
