It is currently Thu Jan 18, 2018 12:03 am
 Post subject: Goose neck
PostPosted: Tue May 22, 2012 10:14 am
Hi,
I don't know if "goose neck" is the proper term, but I'm talking about the fitting that is on the mast end of the boom, that slides down into the boom.
My goose neck is able to slide in and out of the boom by about 1 inch.
Is this proper, or has something come loose inside my boom?
Wallace
 Post subject: Re: Goose neck
PostPosted: Tue May 22, 2012 10:39 am
It's proper. There's either a cotter pin or circlip on the inside end of the boom pin that keeps it from coming all the way out.
Jerome Vaughan
Hobie 16
PostPosted: Tue May 22, 2012 2:03 pm
Thansk Rattle,
One less thing I need to have repaired....
W
PostPosted: Sat Sep 22, 2012 7:56 pm
The E clip on my boom pink has broken off inside my boom. Do I need to take the endcap off, replace it and re-rivet or will it sail without it?
PostPosted: Sun Sep 23, 2012 10:30 am
Double post
PostPosted: Mon Sep 24, 2012 10:55 am
It will sail just fine w/o the clip. However, if you completely remove the boom from the sail, there will be a chance of the gooseneck falling out/getting lost without your realizing it. Can't imagine any other consequence.
Jerome Vaughan
Hobie 16
PostPosted: Mon Sep 24, 2012 1:21 pm
Yeah you should probably drill out the rivets on the end cap that houses the goose neck assembly, pop the end cap off and put the clip back on the goose neck. Then rivet it back together. That's what I did anyways.
1972 Hobiecat 14
PostPosted: Tue Sep 25, 2012 7:50 am
There were 2 types,,, see this previous post/
viewtopic.php?f=14&t=40854&hilit=goose+neck
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
Users browsing this forum: Majestic-12 [Bot] and 4 guests
