It is currently Fri Jan 19, 2018 11:31 am
 Post subject: Main Halyard
PostPosted: Thu Oct 18, 2012 9:28 am
Needing to replace my old and weathered main halyard for my H16's comptip mast. What's the difference between the halyard for a comptip mast vs a non-comptip mast? Can the non-comptip version be easily adapted for comptip use? Old to sailing but new to H16. All wisdom here is appreciated!
 Post subject: Re: Main Halyard
PostPosted: Thu Oct 18, 2012 11:13 am
Hi...
You'll want to replace it with a halyard for a comptip mast. The reason being that the swage that catches in the hook at the top of the mast is located in a different spot which will affect how high up the mast your sail goes.
I just saw one on ebay here: http://www.ebay.com/itm/Hobie-Cat-14-16-Main-Halyard-Comptip-Mast-/271030941106?pt=Boat_Parts_Accessories_Gear&hash=item3f1ab3f5b2&vxp=mtr
2011 H16... Have a Hobie Day!
1983 H14 Turbo...
PostPosted: Thu Oct 18, 2012 11:20 am
Just so they don't mix them up on you...the halyard for the all aluminum mast is mostly wire. For the comp tip it is mostly rope.
Users browsing this forum: hrtsailor and 5 guests
