It is currently Tue Jan 16, 2018 2:37 am
PostPosted: Mon Nov 26, 2012 7:41 am
Saw some inspection ports with bag inserts, what do you use for dry storage? I have a fitting where the side stay or shroud attach that is moving a bit, I thought I could get at that and create some dry storage, just not such a huge fan of cutting holes. Should that have some movement? On the other hull that same fitting has no movement at all. Thanks
PostPosted: Mon Nov 26, 2012 2:00 pm
ummm, not sure about other boats but on my 84 H14 the shrouds are attached on the side of the boat with a "bar" that is under the lip of the hull, not inside. So unless you just really want to install an inspection port for drying and storage you shouldn't need to do that to tighten up that connector.
Or are you talking about something else? Nothing else is attached to the inside of the hull except all of the rudder side attachments and of course the posts for the frame.
1984 Hobie 16
PostPosted: Mon Nov 26, 2012 5:08 pm
Got it, make that the dumbest question.
Users browsing this forum: Google [Bot] and 3 guests
