It is currently Thu Jun 29, 2017 1:04 am
 Post subject: Hobie 16 mast question?
PostPosted: Mon Nov 26, 2012 7:46 am
Once the mast is raised with the pin inserted, it then needs to be removed so the mast can rotate. So, the only thing keeping the mast in place after that are three stays? And the weight of the mast?
PostPosted: Mon Nov 26, 2012 10:14 am
Yes.
PostPosted: Mon Nov 26, 2012 1:35 pm
Also once you have the sail up it acts as a back-stay.
Sail # 10505 or 277
Image Image
PostPosted: Mon Nov 26, 2012 4:33 pm
The forestay is loose so there might be room for the mast to lift out of the socket but once the jib is up and the jib halyard tightened, the mast is held down in place. The jib luff wire becomes the forestay.
Howard
