http://www.hobie.com/forums/
Tips for lacing a tramp?
http://www.hobie.com/forums/viewtopic.php?f=14&t=45948
Page 1 of 1
Author:  Bodhi [ Mon Dec 10, 2012 5:24 pm ]
Post subject:  Tips for lacing a tramp?
Just put a new tramp on and my arms and hands are sore! Seemed tight as I was lacing it but after the kids tested it out, my lacing seems loose! Any tips, please
Author:  jonh [ Mon Dec 10, 2012 6:47 pm ]
Post subject:  Re: Tips for lacing a tramp?
Hey Bodhi
lots of good tips can be found using the forum search as it has been covered.
Like this (scroll down a bit)
viewtopic.php?f=14&t=12697
Matt says to use your mainsheet to pull you side rails in a bit while lacing. viewtopic.php?f=20&t=34849&p=140415&hilit=tramp+mainsheet#p140415
good luck!
Author:  Bodhi [ Mon Dec 10, 2012 8:11 pm ]
Mainsheet trick looks like it would help quite a bit. Thanks
Author:  PurdueZach [ Mon Dec 10, 2012 8:13 pm ]
Mainsheet or ratchet straps
Author:  On1Hull [ Mon Dec 10, 2012 9:29 pm ]
Tighten it up, let your kids jump on it. Tighten it again. Get 2 vise grip pliers, adjust them so they pinch hard on lacing. Pull it tight,grommet by grommet. Or you can do like I do "sail sloppy". ;)
Author:  PurdueZach [ Mon Dec 10, 2012 9:32 pm ]
Also when I tightened mine I let the mesh tramp sit out in the sun on a hot summer day to get it nice and warm. Not sure how much this matters or even if its possible with it being December right now.
Author:  BrianCT [ Tue Dec 11, 2012 1:52 am ]
Buy a $5 hockey skate lace hook and use it along with a vicegrip. Makes it *much* easier to tighten the lacing and saves your hands.
Author:  Bill 404 [ Tue Dec 11, 2012 5:01 am ]
I always tighten my tramp with 1/4" low stretch line, nearly too tight then lace 5/16" bungee through the grommets and pull it tight as I go.
This only works with a factory tramp as after market tramps use smaller grommets that are too small to lace both bungee and line through.
With this method you end up with a really tight tramp all season long. :D
And who doesn't like a tight tramp! :wink:
Author:  Karl Brogger [ Thu Dec 13, 2012 10:24 am ]
I'd use 1/8" dyneema
Author:  mmiller [ Thu Dec 13, 2012 10:29 am ]
The H16 FAQ has some lacing info: http://www.hobiecat.com/forums/viewtopic.php?f=14&t=12697
We use the mainsheet trick when doing Worlds boats... we do a LOT of boats in a short period. Typically 60 to 64!
mmiller wrote:
We don't have a tramp tightening tool anymore, but the keys are...
New line. Old line gets stiff and is hard to tension with the kinks set in the line at each grommet turn. Then second...
Using the main sheet blocks to bend the sidebars in during lacing. It's quick and it's easy. Especially when rigging 60 boats at a time.
Better than that...
On a 14 or 16 you can "pre-bend" the sidebars before tensioning the center lace. We do not use double grommets down the center and get tight tramps without a huge effort.
Use the mainsheet system. Lay the blocks and line on the tramp "unsheeted" from side to side bar... in the center. Add a line to the base of the blocks that can reach around the sidebar, under the tramp and meet the top block. Tie off. Pad the side bars with some cardboard where the line goes around the sidebars. Sheet the system to bend the sidebars in by over 1". We sheet till the tramp gets a little pucker shape along the sidebar. Cleat the blocks and tighten the tramp using moderate tension. Using the vise grips, dowell or just holding the line at each grommet as you go. Tension the aft lace last and then release the block set.
We use this system and get over 1-2 inches of prebend in the bars for over 1 inch after releasing.
Worst loads on a grommet are during tensioning each one... this saves effort and grommets.
http://www.phpbb.com/
