Trapeze any hobie 16? http://www.hobie.com/forums/viewtopic.php?f=14&t=46218 |
Author: | josephosborne85 [ Fri Jan 11, 2013 9:35 am ] |
Post subject: | Trapeze any hobie 16? |
I'm picking up a 16 this weekend for $900, I know it does not have trapeze wires or harnesses. Is it safe to assume I can pick up trapeze wire kits for it so we can double trap? I'm assuming every hobie 16 has the tang where one can hook in trap wires etc...? Thanks #firsthobie |
Author: | PurdueZach [ Fri Jan 11, 2013 9:40 am ] |
Post subject: | Re: Trapeze any hobie 16? |
I'm fairly certain they all have the tang. Where are you located? |
Author: | srm [ Fri Jan 11, 2013 10:08 am ] |
Yes, there are separate holes on the mast tang specifically for connecting the trap wires. All H16s can be rigged with trap wires. I recommend you download a copy of the Hobie 16 assembly manual from this site. It should answer many questions you may have. sm |
Author: | jmecky [ Fri Jan 11, 2013 12:55 pm ] |
I bet when you pick up the boat you will find the trap wires balled up under a life jacket or something. Otherwise yes, all hobie 16 are set up for trap wires. |
Author: | mmiller [ Fri Jan 11, 2013 3:41 pm ] |
Older boats had a single hole in the tang... still OK to set up as double trap. The new tang makes it easier (3 holes). |
Author: | josephosborne85 [ Sun Jan 13, 2013 1:15 pm ] |
Located on Lake Crescent in NORTHWEST Washington. Hoping to meet with the hobie crew in Seattle once it warms up a bit. I already got that manual! U betcha! ...that's how I knew tang wasn't referring to a citrus drink |
Author: | ASDASC [ Fri Jan 18, 2013 12:57 pm ] |
Now THAT's funny! |
