It is currently Wed Dec 13, 2017 1:32 pm
PostPosted: Fri Jul 19, 2013 5:49 am
I'm looking to buy a Hobie Cat 16. I found this. What do you all think? What should I look for? I already went to view it once.
http://minneapolis.craigslist.org/dak/b ... 80074.html
PostPosted: Fri Jul 19, 2013 3:05 pm
take a really close look for soft spots. that is the most common and most difficult issue to contend with. otherwise, i'l say it is a little pricy considering the age even if all of the parts are there and functional. you could likely buy one 10 years newer for no more than $100-$200 more. good luck!
PostPosted: Fri Jul 19, 2013 6:08 pm
I'd pass unless your budget is really tight. Look for a mid/late 80's version that's someone has put some $$ into recently. You can usually find nice 16's from the late 80's around $1.5-2K if you are patient. What to look for...
Must have:
No softspots
No cracks in fiberglass or aluminum
No blisters in the hull
Look for corrosion anywhere steel is touching aluminum. A little is normal, but if metal is missing beware! (check the mast and boom carefully too)
make sure the mast is straight, no dents or cracks
solid tramp w/ no holes or tears
good/clean sails - must be stored indoors
Has the standing rigging been replaced in the last 5 years or so?
functional trailer with minimal rust
Make the seller rig it with you to be sure you get all the parts & see that it all works.
I would want...
adjustable rudders castings (look for a big screw on the top of the tiller arm right above the transom)
6:1 mainsheet blocks
harken or ronstan cleats/blocks
a Sail box on the trailer and/or beach wheels are a big plus
Garrett
94' H16 - 114050
https://www.facebook.com/groups/423463424425838/
PostPosted: Fri Jul 19, 2013 6:36 pm
haha the seller wants to "downsize" to a moth!
http://youtube.com/optikid16030
1983 Hobie 16 Cat fever #55697
2008 Laser Radial/4.7 #190471
S.S.S.
S.Y.S.P
PostPosted: Mon Jul 22, 2013 5:39 am
Found this 18':
http://minneapolis.craigslist.org/ank/b ... 23624.html
