It is currently Thu Jan 18, 2018 2:47 am
 Post subject: First cat
PostPosted: Wed Oct 02, 2013 5:53 am
I'm looking to get into solo sailing
Should I get a hobie 16 or 14 as my first boat to sail solo?
 Post subject: Re: First cat
PostPosted: Wed Oct 02, 2013 7:26 pm
The 14 is a great solo boat. The 14 is an easy boat to learn on and easy to right yourself. I'd look for a "turbo" which means it has a jib, this makes sailing more fun and tacking easier.
PostPosted: Thu Oct 03, 2013 8:26 am
I am 6'5" 215lbs H16 all the way...
On the H16 if there is enough wind to knock me over, with a properly sealed mast and good technique I can right it solo.... The only trouble I have is if I am goofing off in really light air and capsize being silly..
Or sometimes in really puffy conditions I have to wait for a nice gust to lift it back up...
Solo righting poles are easy to make and allow a 160lb-er to right a H16 no problem..
at 210 lbs... the H14 just isn't enough boat... and will nearly prevent you from seriously sailing with any crew..
www.thehobiewayoflife.com
PostPosted: Thu Oct 03, 2013 11:26 am
I had the same dilemma but went for the H16 and have no regrets.
The H14 turbo as mentioned is a great boat but in my opinion the H16 offers more options.
My biggest issue has been going solo but again as mentioned a righting pole has put this fear to bed.
Check out a post I posted a little while ago title 'Righting system for solo (150lb/10.5st 5'10 skinny git)?' says it all :-)
http://www.hobiecat.com/forums/viewtopic.php?f=14&t=49202
SRG
Hobie 14 Turbo (~1979)
Hobie 16 Carumba (1983)
