It is currently Fri Jan 19, 2018 9:13 pm
 Post subject: Flat bottom
PostPosted: Thu Oct 02, 2003 1:16 am
Hi all,
I'm a delighted new owner of an european 16. After all summer dragging the hulls on the sand the bottoms show quite a wear, starting to flat the hull edges.
Should i be worried?, much?, when?.
What's the standard reshaping procedure? I take it that just gel-coating is not going sharp the edge or am i wrong?
Thanks.
PostPosted: Sat Oct 04, 2003 7:47 pm
Authorized Hobie Dealer
you will need to get fiberglass matt to build up the shape. This isn't the easiest thing to get correct. I would recommend letting someone do it for you that works with glass everyday. There are several systems available with everything you need included pre cut glass. E-mail me for more information.
Thanks,
Brad Stephens
www.sunjammers.com
Panama City Beach, FL
850-235-2281
brad@sunjammers.com
