i've seen many suggested ways to repair a broken gudgeon and sheered screws on this forum. what does hobie recommend?
i've got port holes already in the rear of the hulls but i can barely reach the screws from the inside.
JePense,
I had a gudgeon fail many years ago while racing in the ocean. It was no fun coming back to the beach with one rudder stuck near horizontal.
I was really intimidated by the repair and actually didn't sail for several years due to not knowing how to fix it and not wanting to pay someone else to do it. I had several screws sheer off well inside the transom near the aluminum plate.
I went the extreme route and re-built my transoms. I actually ground everything down to the aluminum plate, removed the old plate and installed a new one, re-glassed everything, drilled and tapped holes for new gudgeons, and installed the new one piece gudgeons. I've been happy with my repair.
Here are a few pics of the process from my repair. I just didn't want to cut ports into the boat, even though I understand some of the advantages.
http://s1319.photobucket.com/user/jsaut ... sort=2&o=0I had zero experience with fiberglass prior to this repair, but I did enlist the advice of a friend with experience. It turned out that this repair wasn't nearly as difficult as I was making it out to be. Should you decide to do something along these lines I'd be happy to give you more detail about the process. But again, I'm in no way an expert on fiberglass repairs. I'm happy to say that my repair is holding up strong after a year of sailing 6-7 days a month for quite a while now.
